Seasoned Crank?
<small>[ November 13, 2002, 11:09 AM: Message edited by: VipZ28 ]</small>
de·flect [ di flékt ] (past de·flect·ed, past participle de·flect·ed, present participle de·flect·ing, 3rd person present singular de·flects)
verb
1. transitive and intransitive verb change course: to change course because of hitting something, or change something’s course by coming into contact with it The pitcher’s arm deflected the ball into the outfield.
The word "deflect" doesn't seem to suggest any bending taking place. Are we talking about a change of course here or some slight bending of the crankshaft taking place? I think it's the latter.
flex [ fleks ]
verb (past flexed, past participle flexed, present participle flex·ing, 3rd person present singular flex·es)
2. intransitive verb bend: to bend or be able to be bent The board flexes as you step on it.
<small>[ November 13, 2002, 11:17 AM: Message edited by: Colonel ]</small>
Your right, but they are talking seasoned blocks when talking about seasoned parts.
Never heard of any talk about seasoned crankshafts in the 25 years I have been playing around with engines and so forth. If givin the choice, I would prefer a new crank to an old one that has big miles on it (newly machined or not).
Hey, I might be wrong... Just sharing this with you.
Ron,
________________________________________________
<small>[ November 15, 2002, 05:39 AM: Message edited by: Kimchee and Rice ]</small>
Anyhow, about seasoned versus green. Here is the deal. People wanted seasoned blocks. This was beacause it usually took several heat cycles to get past any core shift, etc.. That would take place. Also metal act differently once it has been seasoned a bit.
Now, casting technology has come a long way so it isn't as critical. But, to really sason a god part, you can cryo it. That is better than any seasoning process you can come up with. That will stabilize the metal. It will be stronger, and it will machine much better.
As for cranks, since they bend and stress, their heat cycling isn't as critical as the fac that they haven't been abused. An Ls1 crank seems like a fairly strong piece for mild street duty.
When racing small blocks I have friends who have used cast 400 cranks for many years in 9 second cars. They replace the crank every 50-100 passes. They'd run aluminum rods to soften the shock to the crank.
Your crank should be fine up until about 500hp after that you might consider a forged piece. Most shops could mag the crank for you if you are wooried, but I wouldn't unless you feel you have a reason to woory. Most good shops can clean the crank and do a visual on the crank and give you a good idea of if it is ok or not. LS1s to the best of my knowledge aren't prone to cracking like some other cranks out there.
Ron...don't you have some beer to drink, some cig's to smoke, and some girls to chase <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Todd
Cranks normally fail due to excessive torsional (twisting) loads. The biggest place for this to happen is at the radius. on a journal. GM sought to keep this from happening so they hydraulically "roll" the filet. This makes a much stronger point on the crank. One of the biggest issues with remanufactured cranks is a shop that doesn't put enough radius on the journal. Production shop in many cases just dress the wheel on their grinder to keep it flat. They do that a few times and destroy the radius on each side of the stone. They don't go back and dress the corners to put the radius back in. When they get into the corner of the journal they cut it at almost a 90^ angle with a sharp transition. Stress risers start here, and the crank breaks. On a race motor often you can make a crank stronger by putting an even more generous radius in the filet on the crank and clearancing the bearings a bit...
<small>[ November 15, 2002, 02:54 PM: Message edited by: J-Rod ]</small>
