What are concerns and problems with installing/running a cam with 110 LSA??
Duration @ .050: 226 Intake / 236 Exhaust .525/.525 Lift with aforementioned 110 LSA
Almost forgot, this would be going in with S2 Heads.
<small>[ November 12, 2002, 11:31 PM: Message edited by: The Dragon ]</small>
Your power will be peakier than with a wider LSA, coming on faster and falling off a bit sooner. You will see higher peak torque and better torque throughout the midrange. You will really be able to feel when you are on this cam and in your sweet spot. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Even with an M6 you may want to program for a higher idle. I did and am idling at 900 RPM with a smaller, 112 LSA cam. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ November 13, 2002, 11:50 AM: Message edited by: verbs ]</small>
That sounds like the ASA Hotcam. Might do a search for that. I know there a couple of folks on here running it.
Edit: Here's one link that may help...
https://ls1tech.com/ubb/ultimatebb.p...1;t=005656;p=1
<small>[ November 13, 2002, 01:40 PM: Message edited by: Fulton 1 ]</small>
<strong>Not many 110 cam users on the board...
Vince
Kechme
Nicky from SDPC
So many 111 lsa cars idle well that I think that you can get a 110 car to idle okay.
Folks talk about reversion when going with more radical LSA's.
I think the cam will peak like 200~ish below that cam on a 112. That cam on a 112 used to be pretty popular (with more lift). I have heard of that cam on a 112 peaking at 6400 most of the time.
Have you been advised to significantly increase compression to fully take advantage of that camshaft, due to bleed off?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was not made aware of the higher compression. How much lost/gained by doing/not doing higher compression?
What do ya think of this? I was thinkin' about TR 224 as well . . .
I'm old-school, I don't mind a lope <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Fulton1: Bingo! ASA hotcam <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>Thanks PSJ for mentioning the compression issue. I forgot to bring that up as well.. It seems that the bigger cams love compression to offset the lowend power loss that is associated with going with a huge cam. However, the 110 lsa will help in that dept.. Whomever you have do your heads make sure you tell them what cam you are running. Have you decided on what castings yet for your heads? I wish my friends would chime in and tell you how my cam idles and the minimal amount of lope you will feel and hear.. Your cam however will lope. I heard the ASA cams are on fast ramps as well, but I am not sure.. Do you have the cam card?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't have the card, but I do think it's a fast ramp.
BTW, guess I should mention this car would see very little strip.
Mainly daily street use <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Ferrea Competition Valves (2.02"/1.57")
- Comp 918 Springs
- Machined Locks, Valve Guides, and Retainers
- Set Valve Springs to Cam Lift
Lift | Intake | Exhaust
100 / 63 / 57
200 / 145 / 106
300 / 215 / 149
400 / 259 / 192
450 / 275 / 207
500 / 284 / 219
550 / 292 / 223
600 / 301 / 225
Any problem with ordering the Thunder Racing Install Kit?
I was also thinking about goin' with the stock gaskets. My exhaust guy said they were VERY good.
<strong>Are your heads 5.3L, 5.7L, 6.0L, or LS6?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">5.7 Stage 2 LS1
Just wondering why so many people are afraid of a cam with these specs <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<strong>There are quite a few running the ASA cam. I am surprised they have not comment on this post. I personally like trying new cams.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Agreed about trying new cams, wonder why noone else has chimed in as well <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
