Cam Grind # question
Old Dec 12, 2002 | 02:07 AM
I8COBRA's Avatar
Default Cam Grind # question
On the cam card under the grind # it states HR114+2
I'm just wondering what does the +2 mean?
Thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 12, 2002 | 03:13 AM
Tin Indian's Avatar
Default Re: Cam Grind # question
Should mean +2 degrees advance "ground in"
I will bet since the LSA is 114 degrees, the IC is 112 degrees. There is your 2 degrees of advance.
Ron,
Old Dec 12, 2002 | 08:25 AM
I8COBRA's Avatar
Ok, but since I'm cam-retarted. Can someone explain to me what does +2 degrees advance mean exactly? Is there anything special that needs to be done during the install?
Thanks again <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 12, 2002 | 09:02 AM
HITMANSS's Avatar
Unless you are planning to change the cam timing, just install it straight up, dot-to-dot.
If you have an adjustable timing chain, you can advance or retard the cam a few degrees. If so, I would degree the cam first. You will need a degree wheel for this.
Let me guess --- did you just buy this cam from Thunder Racing (224/224 114 +2)???
Old Dec 12, 2002 | 10:46 AM
DailyAluminumBlock's Avatar
Advancing the cam 2 degrees means that the intake valve will close 2 degrees earlier then with 0 degrees advance. This means slightly better low-midrange power 1000-5000 with a small power loss at the top end 5000+.
Old Dec 12, 2002 | 11:01 AM
I8COBRA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DailyAluminumBlock:
<strong>Advancing the cam 2 degrees means that the intake valve will close 2 degrees earlier then with 0 degrees advance. This means slightly better low-midrange power 1000-5000 with a small power loss at the top end 5000+.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Cool, thanks for that explanation. Sounds perfect for mostly street use <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The cam is an MTI B1 222/222
Old Dec 12, 2002 | 11:08 AM
MyLS1Hauls's Avatar
The MTI B1 cams are 221/221 and are ground w/ 4* advance usually. You may have ordered the C1(hammer cam), which is a 222/222 .56x lift.
Old Dec 12, 2002 | 11:16 AM
I8COBRA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MyLS1Hauls:
<strong>The MTI B1 cams are 221/221 and are ground w/ 4* advance usually. You may have ordered the C1(hammer cam), which is a 222/222 .56x lift.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nope, its a B1 and they are all 222/222 as far as I know from this board and from my spec card. The only different between the C1 and B1 is the C1 has a 112 LSA and B1 is 114. Both are .560 lift.
Old Dec 12, 2002 | 11:28 AM
MyLS1Hauls's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by I8COBRA:
<strong>Nope, its a B1 and they are all 222/222 as far as I know from this board and from my spec card. The only different between the C1 and B1 is the C1 has a 112 LSA and B1 is 114. Both are .560 lift.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Trust me, ALL MTI B1 cams are 221/221 and have a lift of .558". If its an MTI cam and its 222/222 w/ .560" then its a C1. The T1 is a 112 LSA B1. The C1 cam has more agressive ramp profiles than the B1/T1. Call MTI if you dont belive me <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ December 12, 2002, 11:30 AM: Message edited by: MyLS1Hauls ]</small>
Old Dec 12, 2002 | 11:54 AM
I8COBRA's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by I8COBRA:
<strong>Nope, its a B1 and they are all 222/222 as far as I know from this board and from my spec card. The only different between the C1 and B1 is the C1 has a 112 LSA and B1 is 114. Both are .560 lift.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Trust me, ALL MTI B1 cams are 221/221 and have a lift of .558". If its an MTI cam and its 222/222 w/ .560" then its a C1. The T1 is a 112 LSA B1. The C1 cam has more agressive ramp profiles than the B1/T1. Call MTI if you dont belive me <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah, just checked out their website. I bought the cam as a B1 though, oh well, I guess the C1 is going in <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Not much different between the two anyways, 221 vs.222, still in the same ballpark.
Thanks for info. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ December 12, 2002, 11:58 AM: Message edited by: I8COBRA ]</small>
