No hood, Rained all night what do i do
Old 01-16-2008, 03:46 PM
04ctsvfl's Avatar
Default No hood, Rained all night what do i do
Im getting my hood painted and it wasnt supposed to rain last night and it did, all into my engine bay. What should I do? Attempt to dry off then start and cook the water off, or do I wait till all the waters naturally evaped. Thanks
Old 01-16-2008, 03:48 PM
jmm98LS1's Avatar
I wouldn't worry too much about it. Blow the water off with a leaf blower or something & fire it up.
Old 01-16-2008, 04:09 PM
Happy Jim's Avatar
Imagine how wet the engine bay gets when you're driving along and the rain is hammering down....start her up!
Jim
Old 01-16-2008, 04:13 PM
bczee's Avatar
Should not be a problem, GM and other have spend a lot of $$ on R&D for those connections and parts.
I have cleaned some of my older car engine by just spraying it down with Gunk Engine cleaner and then just hosing it off.. I has always started up and ran for me.
But as jmm98ls1 stated, blow or dry off what you can if your really concern about it.
Old 01-16-2008, 04:14 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Uh... After loosing an engine possibly due to a rain storm I'd absolutely advise against starting it right away. I'd try and dry it off / let it dry. Pull the plugs and turn it over by hand in an attempt to get any water that could have possibly gotten in there out.
Old 01-16-2008, 04:16 PM
99z28monster's Avatar
screw that start that thing up it is just rain not like it was dipped in a lake or under high pressure water. It will be fine.
Old 01-16-2008, 06:15 PM
418redz28's Avatar
the rain dose not have a direct path to the intake so i say start her up!
Old 01-16-2008, 10:37 PM
rsodeputy61's Avatar
Originally Posted by Beaflag VonRathburg
Uh... Pull the plugs and turn it over by hand in an attempt to get any water that could have possibly gotten in there out.
aaaaaaaaaahahahahahaha! start the damn thing up, geez... i spray my engine bay off all the time, never a problem. unless u submerged it?
Old 01-16-2008, 11:12 PM
BigBirdTA's Avatar
For all those saying just start it up, I agree somewhat because your only option is to take the intake off. You might want to know that water does seep between the heads and the intake thru the headbolt groves (see bottom pic), the front under the intake and the back under the intake. All of it goes onto the valley cover.
Now, that by itself would normally not be a problem if the rubber seals did a good job of sealing the knock sensors up. Unfortunately, heat causes seals to dry up and shrink leading to loss of the seal. Once that happens, if enough water that get's in there, it will puddle and reach the knock sensors and they will rust and eventually die. See pic below.
When I put my 408 in, I made damn sure the knock sensors were sealed good with plenty RTV before putting the intake on. See 2nd pic.
A tarp is always a good idea, no matter what the weatherman says. And it's inexpensive. Live and learn...
Old 01-16-2008, 11:26 PM
good idea on the knock sensors
Old 01-17-2008, 12:26 AM
robertbartsch's Avatar
I routinely cleaN MY ENGINE WITH the green goo and a garden hose. i have done this with many cars for years - no issues if you are not spraying down the intake or directly on the pcm.
...let it dry a while since the rain my have soaked the pcm... that is the risk.
Old 01-17-2008, 02:59 AM
99mongooSS's Avatar
I did the same exact thing on my head and cam install
Old 01-17-2008, 07:16 PM
CodeRed2000SS's Avatar
just start it up, i clean mine all the time
Old 01-18-2008, 07:07 AM
Black02SLPSS's Avatar
Fire it up. You wont have anything to worry about especially if your running a stock lid, because by some act of god the rain would hafta get under the lid then make a verticle leap through your airfilter and continue upward until it gets out of the lid. Point being your not going to injest any water so you wont have problems. FWIW my car sat ouside of a body shop with no hood and a half *** rigged up stock air induction system for over 6 months, through rain sleet snow shine and thunderstorms. You will be fine.
Old 01-18-2008, 08:16 AM
amen brother
Old 01-18-2008, 11:29 AM
qwk93ta's Avatar
Just be glad you don't have an OPTI.
Old 01-18-2008, 11:38 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
When I clean my engine bay, I use pressurized water at the car wash on it. Never had 1 problem. Geez! I swear there are some very paranoid people in here!
Old 01-18-2008, 02:03 PM
I pressure washed my engine once and managed to get some sensor wet, which ended up making my starter engage while driving down the street, or just never disengage from starting it lol. Will that stop me from washing my engine bay in the future? No, but ill prolly not use the high pressure washer on it.
Old 01-18-2008, 03:20 PM
Trev_SS's Avatar
Just Fire it up nothing gonna happen just make sure that your air filter isn't soaked i did that one time with my car the filter was soaked fired it up and it had a heal of a smoke out the exhaust but i was only from the water in the filter took the filter out and it was soake ran fine after that.
Old 01-19-2008, 08:53 PM
BigBirdTA's Avatar
Yep! I guess I'm so paranoid, I just "imagined" the rusted front knock sensor and "imagined" I had to temporarily tune out the code when the sensor went dead until I could pull the intake and replace it...
Wait till those rubber seals dry out in your car.
