ls7 lifters questions inside
Old 04-04-2008, 10:25 PM
bigfatls6's Avatar
Default ls7 lifters questions inside
Will ls7 lifters work in an ls1 and are they better than stock ls1 lifters? How do they compare? I have heard the caddy lifter are pretty good which are better?
Old 04-04-2008, 10:50 PM
72chevelle6.0's Avatar
From what I have found the LS7 will work in a ls1. The LS7 are rated for a higher RPM. while the Caddy's are even higher (can't remember the RPMs off the top of my head)
Old 04-04-2008, 10:52 PM
here is one of the links talking about the lifters https://ls1tech.com/forums/generation-iii-internal-engine/580707-new-upgraded-hydraulic-roller-lifters-sdpc.html
Old 04-05-2008, 08:23 AM
RGKSR's Avatar
Default LS7 lifter = LS1 Lifter replacement
The LS7 lifter is the factory replacement for the LS1/6 part.
Bob K.
Old 04-05-2008, 08:31 AM
SOMbitch's Avatar
Bob K.
^^^^^^^^^^^ Yep. I have set sittin on the air hockey table waitin to go in.
Old 04-05-2008, 09:20 AM
john563's Avatar
ls7 in mine
Old 04-05-2008, 09:47 AM
PREDATOR-Z's Avatar
Bob K.
Correct
Old 04-05-2008, 10:07 AM
cast iron's Avatar
What type of preload is recommended? Wild shot here, would they work in an early 90's SBC?
Old 04-16-2008, 02:04 PM
Racer383's Avatar
Did anyone the switched to the LS7 lifters note they are slightly noisier then the stock LS1's?
Old 04-16-2008, 02:06 PM
BIG_MIKE2005's Avatar
Nope. But when I did lifters I did a full H/C swap, so all around valvetrain noise had a slight increase.
