blue oil pump o ring
This is holding up the whole show. The Best V8 Stories One Small Block at Time
Maybe its not a problem, maybe the pickup tube isn't supposed to "snap" into place with the blue o ring as it did with the old o ring. Anybody here install a new oil pump? Did you notice what I'm talking about? 1)I hold down the pickup tube and insert the pump rotated slightly counter clockwise.
2)when the pump slides onto the shaft I rotate it down and insert the pickup tube into the pump.
I can't see any other way to do this.
I've been at this for over 3 hours now. I've bought a new o-ring from a chev dealer. What am I doing wrong here?
Still no resolve on the oring mounting issue so if someone can provide some guidance I would greatly appreciate it.
Holy crap I had no idea this was such a major procedure.
How many pieces are in the pump. I don't want to pull the front cover and find out I have no idea how to get it back together correctly. Again, the ramifications of a wrong decision here are at best a huge effort to fix and at worst catastrophic (oil pump failure = engine damage).
Freakin out here.
