View Poll Results: Which would you prefer?
230/230 .612/.592 xfi/xer 111+2 lsa
11
29.73%
228/232 .598/.600 xfi 111 lsa
26
70.27%
Voters: 37. You may not vote on this poll
Which cam? 230/230 or 228/232
Old 05-11-2008, 07:16 PM
TA1364's Avatar
Default Which cam? 230/230 or 228/232
1. 230/230 .612/.592 xfi/xer 111+2 lsa
2. 228/232 .598/.600 xfi 111 lsa
Well through tons of researching and reading I have narrowed it down between these 2 cams. Basically I just want to have a solid 11sec car.
I know the first cam has .08x ptv clearence on one side, would this be ok for DD?
What do you guys think?
Old 05-11-2008, 07:37 PM
Fb0dy0nly's Avatar
I like the second one but you prob see why.....
Old 05-11-2008, 07:40 PM
rocksws6's Avatar
I would take the first of the 2 myself. I actually have something similar. (230/232 110+2) Your question was pretty vague though. Need a little more info for a cam recommendation. That and the 2 cams you picked are very similar. The difference between them is going to be very small. I'm sure you will be happy with either one though.
Old 05-11-2008, 07:45 PM
TA1364's Avatar
Some more info: DD, lower shift points the better, want to go 11s near full weight. Any other ideas I cant think of?
Old 05-11-2008, 08:04 PM
rocksws6's Avatar
I don't know if you seen it or not but Chris1313 got deep into the 11's with the first cam you listed. He's got some weight reduction done but its definately a proven cam.
Old 05-11-2008, 08:27 PM
Paint_It_Black's Avatar
I would like the 230/230 more, but I am going to recommend the 228/232 because your exhaust system is weak, and you'll need the extra duration and lift to compensate.
Old 05-11-2008, 08:29 PM
Ryan L's Avatar
I don't think you are showing the correct lifts for the XFI lobes on the second cam.
Old 05-11-2008, 08:30 PM
XFI lobes have 2 different lifts for each of their durations. Different lobe numbers.
Old 05-11-2008, 08:31 PM
Ryan L's Avatar
On stock rockers? I thought they were all ground the same.
Old 05-11-2008, 08:36 PM
stock rockers.. aftermarket rockers.. doesn't matter.. I'll put it another way.. there are 2 different lobe lifts for each duration in the XFI lobe line.
Old 07-02-2008, 03:46 PM
PBMFIsMe's Avatar
What I would have said exactly.
Old 07-02-2008, 03:49 PM
ThirdGenLS1's Avatar
yes one is an exhuast lobe and the other is a intake lobe. Either one you'll prolly be very happy with. Just throwing it out there but i have a 228/232 112+2 cam patrick G helped me spec out a couple of years ago. Its on lsk lobes though so i would recomend a good dual spring if you dont have one. But i'll let it go for 250 shipped, just throwing it out there as an option incase you are on a budget.
Justin
Old 07-03-2008, 03:59 AM
PREDATOR-Z's Avatar
The first one is more powerful.
There is no 228 or 232 advertized durations in XFI (228/232 are XE-R)
The 230/230 would be perfect for your setup, I recommend PP or PRC Gold Dual springs and 7.425 pushrods.
The specs are:
Intake lobe # 3016r
Exhaust lobe # 3725r
111 LSA
109 ICL
It is called "El Torro" cam, "The Bull"
Old 07-03-2008, 06:05 AM
khaotic's Avatar
Default Cam
I would call someone like cam motions or another reputable cam grinder give him your exact specs and have the cam ground to how you have the car setup then their is no quessing and the cost to have one custom ground the same cost or sometimes less.
Old 07-03-2008, 07:09 AM
PREDATOR-Z's Avatar
No guessing, I am this grind's designer, Chrs1313 got the specs from me.
It is not a cammotion lobes, it is a XFI/XE-R Comp Cam grind.
Old 07-03-2008, 08:02 AM
04gtod's Avatar
Why the xer exhaust lobe. Doesn't mixing the xfi/xer give you 2 different base circles on the lobes? Won't your pushrod length be different on the intake and exhaust? How much HP would I pick up going to a 230/230 from my 224/224 cam?
Old 07-03-2008, 03:35 PM
TA1364's Avatar
The specs are:
Intake lobe # 3016r
111 LSA
109 ICL
Well I went with the 228/232
I thought I read that around here somewhere about that combo cant be on xfi lobes but the sponsor I got the cam from said it was on xfi lobes.
Looking at the printout from comp, how do you know what lobes were used?
Maybe the 230/230 would have been better but I think i'll be able to hit 11s with this cam anyway.
Old 07-03-2008, 05:11 PM
PREDATOR-Z's Avatar
Well, your sponsor must be a magician. XFI come in 224 intake and then 230 so no 228
and exhaust is a 230, then 236 no 232, and the 230 has .604 lift.
Either you got the info wrong or that sponsor is pulling your leg
Old 07-03-2008, 05:17 PM
PREDATOR-Z's Avatar
to make more trq in midrange lifts
yes
no 7.425 cam only (hydraulic lifters will eat the difference.
The 230/230 is 60>65 rwhp cam properly tuned and installed.
Old 07-03-2008, 06:48 PM
chrs1313's Avatar
yes
yes it is great cam that i love...
guess which one i voted for...
also i got 7.4 in pushrods and the stock lifters ate up the slack...it is about at the max though so predator is dead on recommending 7.425 pushrods...
gave me 70rwhp with cam, and 85mm lid/maf only changes...
Quick Reply: Which cam? 230/230 or 228/232
