need 0cc pistons for 6.125 rods
hi
from where can i buy 3.905 flat top pistons 0cc valve reliefs for Scat 6.125 Premium I-beam Rods
thanks
thanks
Just get the Diamond -2cc pistons & call it good. There is nothing wrong with a little bit if extra PTV clearance. And your not gonna lose very much in the compression area with the -2cc pistons either.
Can I ask why you want the flat tops so badly? You really aren't going to loose much power at all with the -2cc's, seriously. I really think that it's a better choice with a cam as big as you're going with.... but if you're stuck on the flat tops then it's your call.
Just mill them .030" On that head it will give you a 59cc combustion chamber. you should keep your CR as high as possible if you plan on nitrous. Nitrous loves compression. But if you mill at all you'll need to get the -2cc pistons no question. You should get them anyway, they aren't going to hurt your CR enough to even notice. There's not reason not to. None.
