How drivable is a low compression NA setup? Tune?
Reason I ask is I just finished my 8.7:1 347ci install. I've drove it twice (still untuned based off stock pcm) and it's really sluggish... for example if you try to put your foot 1/2 way into it at 2500 rpms it surges & basically laughs in your face and says "not going to happen." Anything over 2000rpms you can't gun it, though you can SLOWLY build rpms & speed. It seems to drive normal grandma shifting under 2000rpms.
How much will a tune fix this? I'm debating whether I should keep this motor or not since I don't have the funds to finish the turbo project, also I've either got to sell it or re-finance it. Wonder how much it'd cost to have a machine shop swap the dished pistons out?
a tune will fix all of that. it should run smooth, not exhibit 'weirdness' at any TPS % or anything like that. granted it wont have the snot a 12:1 motor would, but you knew that going in and its a turbo project...thats the deal.
but yes, a tune will most def fix your woes. leave it together, finish the turbo someday!
well that's good ^ I may just refinance it then. though it really makes me, and others, sick they added the name Firehawk to the gxp car or whatever it's called.
I don't assume I should buy a tuning program and do it myself since I'm dealing with this low compression motor?
LS1 Tech Administrator
The lower compression, the more timing lead your motor will need. More timing at lower load settings will crispen things up a lot. Check your fuel too because you may be getting too much.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
