missed 3-4, ticking
I just finished changing out the pushrods and the ticking noise is still there. it's a very fast paced ticking a pprrrr sound. I don't know what else could be the problem. It's really loud when I decelerate, and if i push in the clutch it goes away.
can u guys offer some suggestions of what it could be?
thank u in advance
k, so I searched and came to the conclusion that I probably bent a pushrod.
I was at the track and missed the 3-4 shift, lets just say my foot was faster with the clutch than my hand with the shifter. anyways I didn't notice anything after I missed it, but the run right after that I started to notice a ticking noise when I was slowing down. so now, I can faintly hear ticking when I accelerate. and I can really hear it ticking ( really loud high pitched prrrrrrr ) when I am slowing down, decelarating. If I push in the clutch though the sound goes away.
If you are lucky, the pushrod is bent. If you are unlucky, potential broken spring is possible in your future, lifter damage... etc
Go grab some stockers from someone that's done a cam swap and put them in your car.
I've been reading up on how to do it, Just haven't found the answers on how to put the rockers on, in the correct order, and turning the engine over to TDC or whatever I have to do for each one etc..
ok so all the threads I'm pulling up don't mention anything about top dead center. But I have a question. If I remove the rockers, will the springs come up with them?? revealing the pushrods? if so i'll try it myself.
Also, when torquing the rockers to 22ft/lbs. can I just unplug the plugs and injectors and turn the motor over like that to recheck the torque?
Hope yours aint this bad...
Breaking things is the price you pay for racing. It's a case of finding the weakest link most of the time, and drag racing will show what's the weakest link.
To change the pushrods, remove the coil packs, then the valve covers, then take the valve cover, flip it over, and take off the rocker arms placing them in the valve cover. Now the pushrods will come out.
If you are stock internals, there's no real reason to replace valve springs, but stay off the rev limiter because the limiter is hard on valvetrain parts. The rev limiter is to your valvetrain what wheel hop is to your drivetrain. It can kill it pretty quickly if you're not careful.
