L92/L76 Head milling ?
But lucky for me I wanted a smaller camshaft. PLus everyone else is also seeming to find that smaller cams work better with L92 heads.
With my current cam (234/246 EPS) I am running .052 stock head gaskets, no PTV issues, my 6800 rpm shifts would find that for me in a hurry. It was only worth about .3 cr increase from the thinner gaskets. I am running 29* of timing right now with no knock. Once I get back to the strip I will add and subtract a couple of degrees to see what that does.
Excellent driveability and idles at 850.
You need to be realistic with your goals for the car. My old car was ok, but very weak up top, ran out of air with these heads. Low MPH showed that at the strip. On the street it was fine. The new cam already shows a difference in the VE and MAF tables. Much more air flow. I have a ported L76, 100mm LS3 MAF with a Amsoil oil-less cone filter. My kPa drop is only 2 kPa.
Just measure your own parts, part stack up is different on all mass produced engines.
This is key, tolerance stackup can have a large impact. Thats why anyone swapping cam should check for themselves.
