LS9 valve covers
i cant stand that it has a breather hole up front. and that the oil fill hole is in the back on the driver side.
John is there any future covers coming out that will be more LS f-body friendly.
You do realize that if you put the valve cover on the other side of the engine that the oil fill hole then fills from the front passenger right? And by doing so, the breather is then on the back drivers?
i know i am just being picky. worst case i can fill in holes with weld and sand it smooth then coat them.
how many sets you have in stock?
I have 2 sets on hand.
FYI though, that breather tube screws in to the valve cover and could easily be plugged.
Does anyone know if the LS3 & LS7 fuel rail inlet clears the coils as well? I would hate to buy a set and find out that the fuel rail inlet was in the way.
I'm sure the LS9 fuel rails must be total different as the supercharger is in the way.
DJ
I know there have been a few tests of said coils etc, but there are a few points that are not address, but in this case ill keep my opinions to myself and just say your results will vary.
