Spark plugs
Old Apr 22, 2011 | 11:41 PM
2000dreambird's Avatar
Default Spark plugs
whats the best plugs to run in my LS3 once its in my TA and ready to run im thinking NGK but which ones its got ported L92's and a LG cam 114 LSA??
Old Apr 26, 2011 | 11:40 PM
Old Apr 27, 2011 | 10:21 AM
Danny's Avatar
I would use the NGK TR55. I've used NGKs for years with no problems and they're cheap. So replacing them is like $25 for the set.
Old Apr 27, 2011 | 10:44 AM
ClubPlug.net's Avatar
Hi 2000dreambird
I think it should be the TR5 and not the TR55, the TR55 have a larger gap setting.
TR5 V-Power Plug, 14mm Thread Size, 17.55mm (.691") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Removable Terminal Nut, Projected Tip, V-Power (V-Grooved Center Electrode), .040" (1.02mm) Gap, Heat Range 5
TR55 V-Power Plug, 14mm Thread Size, 17.55mm (.691") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Solid Terminal Nut, Projected Tip, V-Power (V-Grooved Center Electrode), .060" (1.52mm) Gap, Heat Range 5
If you want something that will last longer so you don't have to change them sooner, you can always upgrade to the Iridium version TR5IX
But the old fashion copper TR5 will do the trick.
Old Apr 27, 2011 | 11:16 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
^^Not the best advice!
OP: You'll want the wider gap! We typically on the NA combos gap them .050-.055" for the best performance, and GM did from the factory as well!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 27, 2011 | 11:20 AM
Danny's Avatar
Originally Posted by ClubPlug.net
Hi 2000dreambird
The TR5 is for a stock or near stock engine. He has heads/cam so the TR55 is the one he needs.
Old Apr 27, 2011 | 11:30 AM
TR5 and TR55 are the same plug, heat range and all, just with a different nut on the end and a different gap!
__________________
Old Apr 27, 2011 | 12:07 PM
Danny's Avatar
You're right on that. I was just recommending the TR55 since it already has a .55" gap VS the TR5 having a .40" gap. You should never change the gap on the plugs by much.
Old Apr 27, 2011 | 12:34 PM
00nbmz28's Avatar
I would atleast run a 6 heat range, no reason not to. Doesn't hurt anything and you have a less chance of detonation
Old Apr 27, 2011 | 12:39 PM
Hi Guys
Since we are talking about "Gaps".
A properly gapped plug will be wide enough to burn hot, but not so wide that it skips or misses at high speeds, causing that cylinder to drag, or the engine to begin to rattle.
As a plug ages, and the metal of both the tip and hook erode, the gap will tend to widen; therefore experienced mechanics often set the gap on new plugs at the engine manufacturer's minimum recommended gap, rather than in the middle of the specified acceptable range, to ensure longer life between plug changes. On the other hand, since a larger gap gives a "hotter" or "fatter" spark and more reliable ignition of the fuel-air mixture, and since a new plug with sharp edges on the central electrode will spark more reliably than an older, eroded plug, experienced mechanics also realize that the maximum gap specified by the engine manufacturer is the largest which will spark reliably even with old plugs and will in fact be a bit narrower than necessary to ensure sparking with new plugs; therefore, it is possible to set the plugs to an extremely wide gap for more reliable ignition in high performance applications, at the cost of having to replace or re-gap the plugs more frequently, as soon as the tip begins to erode.
Old Apr 27, 2011 | 01:33 PM
Understood and I agree
__________________
Old Apr 27, 2011 | 02:24 PM
also remember that i'm not running the LS1 anymore im running a LS3 with ported L92's and a LG cam with a 114 LSA
Old Apr 27, 2011 | 02:29 PM
What compression ratio?
__________________
Old Apr 27, 2011 | 02:51 PM
not sure off the top of my head,, the block, internals, and heads are coming from you guys.
Old Apr 27, 2011 | 02:53 PM
Stock LS3 short-block, or a stroker?
__________________
Old Apr 27, 2011 | 03:01 PM
stock
Old Apr 27, 2011 | 03:17 PM
TR55's and be done.
__________________
Old Apr 27, 2011 | 03:19 PM
gapped as is or?
Old Apr 27, 2011 | 03:20 PM
I'd go .050" to start.
__________________
Old Apr 27, 2011 | 03:35 PM
whats your take on breaking the motor in when it is ready to go, someone said warm it up to temp, them cool it re-torque the heads and headers, after that put 500 miles on it change the oil (using joe gibbs) put 1000 miles on it then change it to mobile 1 then baby it for the first 5000 taking care not to hold at any one RPM,option to was to warm it to temp, re-torque then get it on a dyno an rev it to 7000RPM 10-15 times to seat the rings,,,,, whats you opinion
