PCV Routing W Baffled Valley Cover?!
Anyone have info on PVC Routing....Running After Market Valve Covers w NO Vents on them, LS7 style Valley Cover w the Black Baffle box built In, Ls7 Stock Intake manifold, and A catch can which Iv been lookin at getting a Rev Tech
Now does the Baffle box under the valley Replace the PCV valve? and how to prop route this!
Run a length of hose from the valley cover outlet to the catch-can inlet, then CC outlet to intake (side) inlet. For the fresh air inlet get a pcv breather(remove the pcv valve) that will fit into the oil fill on the passengerside valve cover.
That's how I did mine.
BTW, the RevXtreme CC has a built-in pcv, at least mine does.
Here's the pcv breather on mine.
http://i523.photobucket.com/albums/w...orlaxr1011.jpg
I just realized the I left out the part about running a short length of hose to the TB.
