Actual L92 head combustion chamber size and Cam Choice help needed
I kept hearing from every cam company, magazine article and every person on the LS forums how the combustion chamber on the L92 heads is 70cc-71cc. I work where I can get the blueprints and they say that the ccs should be 68.4. I finally got my new heads the other day so I thought I would check. The are right to GM specs. I showed about 68.5 on one of my chambers. The magazines keep saying 70 which in my case messes with my numbers. I have a LQ4 with the dished pistons. GM spec, 6.7cc dish, this was also confirmed. So all of the truck engine people, with the 68.5cc heads, +6.7cc dish, .010 piston over deck and a .045 4.030 Cometic head gasket, I show that should be able to get 10:1 cr. Not bad for a street engine and no machining costs.
I just have to pick out a cam now. I have been playing with Desktop Dyno and Quick and Dirty Cam Spreadsheet. I have been recommended cams all of the map from Crane and Comp. After testing a ton of different scenarios in the software mentioned, the best cam looks like this so far. I know if seems low but who knows:
69 Firebird
3.73 gears
4L60E
L76 intake
90mm tb
Z06 MAF
CAI
3400 stall
10:1 CR
Lift = .564 intake
.571 exhaust
Duration:
intake = 220 (advertised 273)
exhaust = 228 (advertised 281)
Overlap=53
LSA 112
ICA 108
IVO=28.5
IVC=64.5
EVO=76.5
EVC=24.5
Timing= +4
This shows 507hp @6000 and 505tq @4500
static compression ration=10.06
dynamic compression ration= 8.04
These are Comp Cams lobes - 3713 3717
If someone can plug these numbers into their software to see what they think I would appreciate it.
69 Firebird
3.73 gears
4L60E
L76 intake
90mm tb
Z06 MAF
CAI
3400 stall
10:1 CR
Lift = .564 intake
.571 exhaust
Duration:
Overlap=53
LSA 112
ICA 108
IVO=28.5
IVC=64.5
EVO=76.5
EVC=24.5
Timing= +4
You probably miss-entered the IVO or EVC. Check and make sure what the program asked for and what the cam card gives(BTDC or ATDC), its easy to mix it up.
You could easily do a ton better then 507 flywheel. easily. I see your location is lapeer michigan. Maybe contacting a few local shops working with the engine plaform might have some insight.
69 Firebird
3.73 gears
4L60E
L76 intake
90mm tb
Z06 MAF
CAI
3400 stall
10:1 CR
Lift = .564 intake
.571 exhaust
Duration:
Overlap=53
LSA 112
ICA 108
IVO=28.5
IVC=64.5
EVO=76.5
EVC=24.5
Timing= +4
69 Firebird
3.73 gears
4L60E
L76 intake
90mm tb
Z06 MAF
CAI
3400 stall
10:1 CR
Lift = .564 intake
.571 exhaust
Duration:
Overlap=53
LSA 112
ICA 108
IVO=28.5
IVC=64.5
EVO=76.5
EVC=24.5
Timing= +4
my latest cam choice. Remember, this is a street car, with the occasional trip to the dragstrip.
69 Firebird
3.73 gears
4L60E
L76 intake
90mm tb
Z06 MAF
CAI
3400 stall
10:8 CR
Lift = .581intake
.605 exhaust
Duration:
intake = 222 (advertised 271)
exhaust = 238 (advertised 287)
Overlap=51 @.006 and 2 @.050
LSA 114
ICA 110
all @.050
IVO=1
IVC=41
EVO=57
EVC=1
Timing= +4
heads milled .040
.045 head gasket
.035 quench
static compression ration=10.8
dynamic compression ration= 8.5
69 Firebird
3.73 gears
4L60E
L76 intake
90mm tb
Z06 MAF
CAI
3400 stall
10:8 CR
Lift = .581intake
.605 exhaust
Duration:
LSA 114
ICA 110
all @.050
IVO=1
IVC=41
EVO=57
EVC=1
Timing= +4
heads milled .040
.045 head gasket
.035 quench
Man you are still leaving a TON on the table...for your setup I would recommend a 112 lsa...lift around .615..on intake and exhaust...and WAY more duration on the intake side ....something like 234 with low 240's on the exhaust
Your idea works to a point. The dynamic compression goes down with the bigger duation on the intake side because the IVC timing goes up. Do you have any exact cam specs in mind, I am open to educated suggestions. Just putting the biggest cam in this setup does seem to work from what I have seen and heard. I haven't chosen a cam yet because of this, I want to get it right the first time.
Be careful! I've used DynoSym software to analyze my engine combinations and have always ended up with overstated HP/TQ software computer numbers. I’ve seen numbers overstated by as much as 50HP. Thus, you may need to go with more camshaft than the computer tells you to meet your goal in real life. I'm currently traveling on business, so I cannot plug your numbers into my home computer software.
Livernois Motorsports Stage II cam that specs out at 232/236 @ .050, .600lift on a 112 lobe separation angle.
Heads un-milled and un-ported. 6 litre LS2 with L92 heads and L76 intake.
"the L92 heads and L76 intake helped the LS2 stomp out 494.9 lb-ft of torque at 5,000 rpm with a very wide torque band. The fact that this combination alsoproduced 546.8 hp at 6,500 rpm seems almost inconsequential."
http://www.gmhightechperformance.com...ads/index.html
![](http://images.gmhightechperformance.com/tech/0702gm_12_z+ls2_engine+.jpg)
i'm curious on what cam to go with on my 408 since i wont be reving it past 6400 this cam looks ok above, not sure if stage 3 would be better or not since i have more cubes then a stock ls2
