View Poll Results: What Intake Manifold to Choose
LS6
26
13.07%
Ported LS2
12
6.03%
TPIS Modified LS6
12
6.03%
Wait for the Weiand
31
15.58%
Don't be an idiot, only the FAST will do
118
59.30%
Voters: 199. You may not vote on this poll
Intake Manifold Choice
Old Jul 30, 2008 | 08:46 AM
rao's Avatar
rao
Default Intake Manifold Choice
402 Aluminum Block with Livernois Stage 3R heads, 230/236 .590/.600 114LSA cam. 1 3/4" equal length long tube headers, dual 2.5" exhaust with high flow cats.
I am swapping the old heads and cam for the ones listed above and I have the following choices for an intake (I have everything except for the Weiand lying around).
1. LS6
2. Ported LS2 with a 90MM TB
3. TPIS modified LS6 with a 90MM TB
4. Wait for the New Weiand
I KNOW that the Fast 90/Fast 92 is the best intake manifold ever designed for any motor ever (except for one that is ported by hand which improves on the un-improvable design ) but I prefer not to go that route.
I am sure this will go badly, but what would YOU choose?
Old Jul 30, 2008 | 08:53 AM
Rapter34's Avatar
I'm waitng for the Weiand to get some numbers before I move anything past my LS6. 'm sure you will be kicking youself if in a month or two (or years knowing Weiand lol) you will be pissed If you spent more for an intake that does not flow as well as the street warrior.
Old Jul 30, 2008 | 10:33 AM
L3THAL_Z28's Avatar
just wait for the weiand...you don't want to end up kicking yourself in the *** later when you find out its the best intake out there and you already spent your money elsewhere
Old Jul 30, 2008 | 11:06 AM
rao's Avatar
rao
Great point. I have #1 and #2 in hand now, which one would you install on the motor during the wait?
Old Jul 30, 2008 | 11:52 AM
JS's Avatar
JS
Jegs and Summit now have the Weiand listed
Ship dates are 8/3 to 8/9
Old Jul 30, 2008 | 02:03 PM
Haans249's Avatar
Put the LS6 on for now.
Old Aug 1, 2008 | 01:52 AM
ringram's Avatar
If its anything like the 2 piece edlebrock timing cover that means August 2009
Old Aug 1, 2008 | 04:40 AM
93TAWicked1's Avatar
I would wait as well. I had the TPIS setup and it did well on my 388 all bore so that is a great setup but its not cheap either...
Old Aug 3, 2008 | 12:47 PM
SSIRBY's Avatar
i dont know bout the other intakes cause i and my friends use the fast 90 and nw 90..
Old Aug 3, 2008 | 01:25 PM
theamxguy's Avatar
TPIS modified LS6 since you have it laying around already! Then wait for an intake comparison; FAST vs Weiand, and make an informed decision. Your combo should be stout. Post up numbers when you get them. Good luck!
Old Aug 3, 2008 | 01:41 PM
DrkPhx's Avatar
A ported FAST intake would work best to maximize the power for his setup. It's expensive but has proven itself time and time again for bigger cube setups.
Old Aug 5, 2008 | 01:13 AM
Fifedogg's Avatar
Just get the FAST. You know your going to wish you did when its all said and done.
Old Aug 7, 2008 | 08:13 PM
Randy WS6's Avatar
On my LS2 i have the FAST
Old Sep 2, 2008 | 10:27 AM
blksbth11's Avatar
If going with what you have, definitely the modified ls6. That should flow very well. I recently installed the bbk manifold and love it, but i had a stock ls1 manifold so anythings better than that.
Old Sep 3, 2008 | 06:30 PM
Tavarez's Avatar
FAST for sure.
Old Sep 5, 2008 | 11:55 PM
LS1BLKSS's Avatar
Banned Village Idiot
Fast F T W ! ! ! !
Old Sep 7, 2008 | 01:21 PM
LS2tiger's Avatar
I'de go with the ported FAST and a good 90mm tb. The ported FAST is a proven setup and they can be had for alot less if you find one used. If later you decide to go with anouther intake the FAST will allways resell without a problem. A Victor jr. is anouther option....?
Old Sep 11, 2008 | 12:05 PM
C_Williams's Avatar
Fast 92
Old Sep 11, 2008 | 12:46 PM
toneloc60's Avatar
My option is a carb intake. They flow more.
Old Sep 12, 2008 | 09:53 PM
donalr76's Avatar
Fast 92 lets the motor breathe. But they are pricey.
