LS3 swap. Need advice
What am I getting into?
Since you have an M6 and don't need the computer they also offer a harness/PCM kit for that crate engine.
19201327 NEW
LS376/480 Controller Kit
• Includes all the components required to run your GM Performance
Parts crate engine (see chart below for detailed list)
• For individual engine controller, use P/N 19201790
19201861 NEW
LS3 Controller Kit
• For individual engine controller, use P/N 19201859
The kits above (P/N 19166567, 19166568, 19201327, 19201861)
include the following items:
19166573 Engine Harness
12576410 Mass Air Flow Meter
19166574 Mass Air Flow Meter Mounting Boss
10367117 Accelerator Pedal Assembly
12581966 Oxygen Sensor (Qty 2 Per Kit)
15156588 Oxygen Sensor Mounting Boss (Qty 2 Per Kit)
19171935 Instruction Sheet
The controller will not function in a production vehicle
unless all kit components are used. These controllers
will not operate any of the production gauges. Aftermarket
gauges are required.
See this thread:
https://ls1tech.com/forums/showthrea...t=gear+cam+ls3
for lots of detail.
BTW, some of the crate engine vendors - Scoggin Dickey, for instance - will do the reluctor wheel swap (and probably the cam gear swap) for you before shipping the motor. I'd also suggest that, although the Hot Cam is fine, there are almost certainly better choices in the aftermarket - check out the C6 tech/performance board on corvetteforum.com.
Yes i've read quite a few threads on the ls3 crate motor and have seen you need aftermarket gauges. I have yet to see the reason though.
Thanks
Thats what Im doing. Im not going through the hassle of an LS3 swap with better choices out there.
If i can get the ls3 computer to play nicely with my stock gauges i don't see how i could go wrong with an almost turn key motor. Knowing that i have no GM parts to start with.
http://www.sdpc2000.com/product/1920...sLS376480.aspx
http://paceperformance.com/index.asp...Category=12524
In that case, I agree BUT I would get a real LS3 cam and skip the GM hot cam. They have much better cams available for the LS3 now
