BIG PROBLEM!!!! Need some thoughts.
As far as being and idiot, try using the shift key, and spell check.
well hech (heck) they dun tought me goad here. maybe you should have listed all of them i prefer lol Central.
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2
Click Banner for Website.Not Just Built.....PerformaBuilt!
You mean to tell me, that if you have a crank with rod journals that are out by .0003, that you are going to polish them until they are within .0001?
I find it amusing that your measuring standards are as high as they are, yet you can't spell to save your ***. It's sponsors, not sponsers. Guess has 2 s's, not one. "I" should be capitalized. You must be the machinist "Rainman".
Even at a half a thou, your tolerances will be +/- a few tenths. Not one tenth.
You're trying to bullshit too many people that know what they're talking about.
I'm sure the cam is hurt as well. Shared the same oil. I'd be surprised if you couldn't clean up and reuse the rods though.
I had this happen to my mustang 5.0 after just 50 miles or so. Same story, you never know. It was built by a engine shop, then when it went out, I built it again myself, it ran strong with good pressure. Never had the issue again.
so the next day comes and they are .0002 larger well how are you gonna make them tighter and then when you do that the next day they are different what are you gonna do. you will spend a year getting a short block together...here is a question for you answer this and I will beleive that yo are as skilled as you say you are
How can you make cam duration longer in a pushrod engine without changing the cam profile. this would be something a precision machinist would do
Please educate me on how you measure and hold tolerances tighter than anyone else in the biz, including the highest level of engine builders. And do so with junk tools.
What equipment do you use? We know you use junk tools, what equipment do you use for you machine work? How much time do you spend assuring all of your tolerances are within .0001 of each other? What do you charge for your machine work?
