My 454 LSX NA Build
Old Apr 3, 2011 | 09:58 PM
  #401
PUNISHER TA's Avatar
Originally Posted by LPE 403
Nice you're getting it together Trevor...!! You have a date in mind when you fire that thing?
I wish i had an answer. but i havent even thought about picking a date yet. still have a lot to do.
Old Apr 3, 2011 | 10:21 PM
  #402
Here's the list I came up with to finish the car.
MSD Starter
Crank Sensor
Knock Sensor
Oil Pressure Sensor
Water Pump/with Heater Outlets Blocked
Tensioner and Idler Pulleys
Intake Manifold Bolts
Oil system
- 10' -10 Hose
- Fittings
- Oil cooler
Exhaust
- Catback
- Cutouts TIG'd on
Radiator Hoses
Computer Mount
Oil Catch Can
Coolant Overflow Can
Intake Plumbing
Crank Pulley
Brake Calipers
Fuel System
Im sure Im missing stuff... This is a start though.
Old Apr 4, 2011 | 04:52 PM
  #403
2000_SS's Avatar
i'm gonig to make a new catch can for my car, i bought enough material for two i think. if you want one, it's no trouble for me to whip one up and have it powdercoated. i'll do it on the cheap for you too
Old Apr 5, 2011 | 04:19 AM
  #404
Sounds good dude. Thats awesome. Thank you!
Old Apr 17, 2011 | 11:38 AM
  #405
New job, so the money is finally back.
Made good progress yesterday, and will be back out there today.
If i can get parts ordered today. and have them by next weekend. I should be able to fire it up then.
Old Apr 17, 2011 | 03:16 PM
  #406
djfury05's Avatar
woohoo great news man!
Old Apr 17, 2011 | 03:29 PM
  #407
LPE 403's Avatar
That's great Trevor, if you get her goin for M&G, you'll have to run it by my place for the after party! Good luck getting if fired up!
Old Apr 17, 2011 | 04:57 PM
  #408
thanks brent. yea. im hoping to have her driving around in the next few weeks. so yea, after party sounds good.
Old Apr 17, 2011 | 05:26 PM
  #409
LPE 403's Avatar
Great! Posted a link on "mi"...check it out.
Old Apr 18, 2011 | 06:23 AM
  #410
Brent, ill be there. sounds like a good time.
Anyways, last night I spent ~1000 at summit on my fuel system plumbing and some other little stuff...
Bought my joe gibbs break in oil.
and spent ~900 at byunspeed on ATI dampner, MSD starter, FAST 85# injectors.
Old Apr 18, 2011 | 08:26 AM
  #411
LPE 403's Avatar
Sounds good!
What fuel system did you get? And why the 85#'s? Seems like a lot of injector.
Old Apr 18, 2011 | 08:30 AM
  #412
O.N.'s Avatar
injectors are way too big.
have a look at this to work out how to get your sizing right for what injector you need.
http://www.fuelairspark.com/Products...rs'-0.aspx
Old Apr 18, 2011 | 05:10 PM
  #413
Sounds good!
I pieced together my own. -8 feed, -6 return...
I think the injectors will be perfect.
650WHP / .8 = ~812FWHP
812 * .5 BFSC = 406
406 / 8 = 51
51 / 85% Duty Cycle = 60#/hr
60 * 130% (E85) = 78#/hr
Old Apr 19, 2011 | 09:33 AM
  #414
O.N.'s Avatar
812 * .5 BFSC = 406
406 / 8 = 51
Yeah a few questions for you what heads(ported/shaved), valves, camshaft duration/lift, compression what does the engine builder think the engine will make.
EDIT: just saw your going to be running E85.....opps.
Your HP figures will probably be close.
looking forward to seeing how it goes, tell me about the heads etc in my above question and engine builder what he thinks.
Old Apr 19, 2011 | 12:02 PM
  #415
No way! Its a secret!... j/k
right now... stock ls7 heads, 244/256 ~.660 lift, aimed for ~11.1 (hoping for 600WHP)
in the next few months, im going to rebuild the top end, with some aftermarket LS7 heads, ~14:1 compression, jesel rockers, a marcella or something, and ill run E98. (Looking for closer to 700WHP)
BTW, i just placed an order for a Go Pro, so ill be posting 1080p videos of the start-up and stuff.
Old Apr 19, 2011 | 01:24 PM
  #416
LPE 403's Avatar
a marcella,
Lol, better plan on a LOOOOOOOOOONG lead time for that one.
Old Apr 19, 2011 | 06:25 PM
  #417
O.N.'s Avatar
why not port the stock ls7 heads you have and shave them to increase comp a little.
mine are shaved 20thou making it about 11:6.1
Old Apr 19, 2011 | 08:57 PM
  #418
how long is your wait?
because i dont want 11.6, if im gonna waste my time redoing the topend... I want to go big...
Old Apr 20, 2011 | 02:58 AM
  #419
O.N.'s Avatar
go the new dr heads then or the mozez.
Old Apr 20, 2011 | 06:14 AM
  #420
Thats exactly what i was thinking.
