RR-STRIKER CAM - Check it out(Vid & Graph)
Here it is guys..Our STRIKER Cam in action. Its not to often we install one of these. Our STRIKER Cam is a 244/256 110 Camshaft. It is designed to have big top end power. It is usually not the cam I suggest for those guys wanting to drive their car everyday. It has 30degrees overlap and is a bear to get dialed in due to nature of surging that this camshaft has, but if someone wants to put a gear in the car like a 4.10 it cleans this cam up nicely due to the fact the rpms are up driving it around making the cam much less noticable. Not only that..the 4.10 gear makes the car with this cam downright VIOLENT as hell
With that being said. This customer brought this car to us. He said the car felt like it had no top end power and felt like it just gave up. Thats when we decided on this package. It already had AR Headers, Camshaft(Customer will release vendor if he wishes), Ported intake, Killer Bee with Beehive and Vette-Air.
We Swapped the Camshaft, Installed MTI Heads, and also a Fast 102mm Intake with 57lb injectors and reworked the Throttle Body. We are also installing a new clutch and a Rockland 4.10 gear set.
You can see from the baseline why he was unhappy with his cammed car. We made 82rwhp at peak and 110rwhp@7000rpms We also gained 40rwtq@peak and 81@7000rpm. We thought this was huge.
Here is the Graph and Vids.
http://www.youtube.com/watch?v=pOPNfR3OviE
I had this cam in my 441 for awhile and to say it's "violent" is quite the understatement! The top end and rpm carryover was undeniable. I switched out for something a little more streetable since I have a 4L60e and A/C in a 3800lb car. I tell ya what though..............I really do miss it!!
