re-use a crank or get a new one.....
Old Sep 8, 2009 | 11:10 PM
LS6427's Avatar
Default re-use a crank or get a new one.....
I have a 4.125 Cola crank. If I send it out to get checked and reworked (whatever it is they do) and it comes back perfectly fine, should I reuse it for a new engine build? Or get a new crank?
Whats the reason you wouldn't use a "used" crank? Its in my 427ci right now and everything is fine.
Old Sep 9, 2009 | 01:50 AM
Busted Knuckles's Avatar
As long as "they" wet mag and check it for dimension/straightness, run it.
Reasons not to run? Cracks would be number 1.
Old Sep 9, 2009 | 11:11 PM
LS6427's Avatar
Any machine shop, or are there specialists for this process?
Old Sep 10, 2009 | 07:16 AM
It'll have to be a decent performance shop, the wet mag setup isn't cheap. A dry powder magnaflux system doesn't work well on cranks, rods, etc., so that's why wet mag is the preferred system. It basically uses a liquid dye that glows under ultraviolet light.
Old Sep 10, 2009 | 08:56 AM
ChucksZ06's Avatar
What is the history of the crank as it sits in your 427? Has it been run hard for a long time? Cranks are very stout pieces if they are taken care of.
Old Sep 10, 2009 | 10:40 PM
LS6427's Avatar
124,000+ miles on my 427ci....100% street driven, never beed to a drag track. Only a street car having fun sometimes. Maybe once it week it sees ~175 mph out on an open highway, other that just daily driven with some fun.
As far as the engine is now...its running like it was new.
Old Sep 11, 2009 | 02:57 PM
ColeGTO's Avatar
Originally Posted by LS6427
124,000+ miles on my 427ci.....
That's an *** load of miles on a performance build. I'm amazed your valve guides and seals haven't given up yet.
As far as the crank goes, have a reputable crankshaft machine shop check it out. There is some worry with fatigue life of a crank, but it really isn't tracked or documented well regarding the useable service life. Basically, if it isn't cracked and it's still straight, run it 'till it tells you otherwise.
Here's the proper process for checking a crankshaft:
Stress relieve
Mag. inspect
Check rod and main journal size
Check stroke index
Index grind rod journals (if required)
Grind main journals (if required)
Re-check stroke index
Polish all journals
Chamfer oil holes
Stroke Index - make sure the stroke is the same for all throws
Rod Journal Size - If they are a lot smaller you'll need a thicker bearing and probably a polish. If the journals are more than .002" smaller I would consider having the crank re-nitrided to maintain it's wear and strength charastics.
Magnetic Particle Inspection - Do a complete and thorough Magnetic Particle Insp., not just a Flourescent Penetrant Inspection. Magnetic Particle Inspection will pickup internal cracks and Flourescent Penetrant Inspection will only pickup surface cracks.
Cole
Old Sep 11, 2009 | 04:35 PM
LS6427's Avatar
Stress relieve
Mag. inspect
Check stroke index
Polish all journals
Chamfer oil holes
Cole
Yea, it was installed in May 2002, its running great. I did have the valve seals redone in 2005, but thats it, they were just getting worn.
So, how much does all that stuff cost and who would you recommened I send it to to get checked?
Thanks.
