ETP Heads and proper rocker arms
So I am sure this has been beat to death but I have a set of 225 et performance heads that I am installing on a 416 cu LS3. Rocker arm selection has been a pain as I dont have 1000+ dollars to spend on rockers. I purchased a set of Harland Sharp rockers from Texas speed but my builder is having issues mounting them or making them work. Will they fit forsure? Does the stock rocker stand that came with the etp heads need to be machined? do the rockers just need to be shimmed? Any help -a link-maybe a picture would really help to make sure we dont screw things up. Any help would be appreciated.
Thanks
Thanks
Done many but made custom spacers on them all. Looked at them on a case by case basis and then made the right stand spacers and they have all worked great. Cary can tell you how much higher or thicker they are. You could measure the difference to see where to get them in the ball park. I don't have any of those stands anymore or I would measure for you and let you know.
any way of making the Harland Sharps work? or do I have to go to a Yella terra? Since i have a set of Harland Sharps already I would like to make them work somehow.... otherwise i may go back to stock for now.
