Got my LS3 427 today!!
Old Sep 3, 2011 | 10:17 PM
  #241
TwoValveKid's Avatar
I ended up going with Mast medium bore ls3 heads
But the fast 102mm LS3 doesnt fit in my C5
Old Sep 4, 2011 | 11:46 PM
  #242
ReeknHavic's Avatar
I thought the LS3 fit in the C5, no problem. What doesn't fit?
Old Sep 5, 2011 | 12:27 AM
  #243
Jimmy P's Avatar
pretty sure he means the FAST 102mm intake
Old Sep 5, 2011 | 12:59 AM
  #244
The highlander's Avatar
Originally Posted by CETAWS6
BTW, these numbers i posted up could of been higher even at 24 degrees but on two pulls the tires broke loose on the rollers. I had it on video but I accidently recorded over it. I have the sheet but it's at home right now and I'm in class. On the sheet, you can see that the hp/tq lopped off cause the tires broke loose and the car was strapped on tight as it supposed to be. Like I said there's more there. I just gotta get on the dyno again and record results.
414 on a mustang dyno is around 467whp on a dynojet.
Extremely low.
I don't think that 24º vs 27º is going to give you 100whp which should be what you should get.
Now, on the other hand... Can you post the tune? I bet the car is NOT running at 24º sorry...
Then again. I installed a 440 from scoggin dickey.........
Old Sep 5, 2011 | 01:44 AM
  #245
CETAWS6's Avatar
To the highlander...well point well taken. I got the car retuned. Last time on dyno, it layed 509/480. I was told the original tune from before was garbage. So the problem has been solved.
Old Sep 5, 2011 | 05:25 AM
  #246
WKMCD's Avatar
If you're talking about the clearance up against the cowl the solution is pretty simple. There is a small pin that secures the wiper tray. Remove that. If you still need more, a couple of thick washers between the cradle and the frame will do the trick.
Old Sep 5, 2011 | 08:02 AM
  #247
1994z's Avatar
ceta are talking about the first tune or the one from v.r. reason i ask is i see you have one from frost.
  #248
Not with Mast heads. lol.
It was hard fouling on the wiper support bracket about 3/4 of an inch before the car met the cradle.
Old Sep 5, 2011 | 08:31 AM
  #249
CETAWS6's Avatar
To 1994 Z...before VR, I took it this shop in Athens called MV Performance. Though they say they tune GM, Ford, and Dodge, they were actually a mustang shop. They tuned my car 1st. So there tuning was garbage. That is when I took it to VR. They dynoed the car and tuned it. Though they made it driveable, it was surging and bucking and cuts off. That's when I got with Frost so he can help with the tuning issue.
Old Sep 5, 2011 | 09:12 AM
  #250
1994z's Avatar
okay, same here took it to a guy in hueytown,ala. everyone said he was the best around. well after he took about 5 hours of trying to get it tuned he let it slip that he was more familar with fords. then he called someone to help him try to to get my car running better. said this guy was better with ls motors. i told my nephew right then i screwed up. i dont think there is anyone around here that really knows ls motors. dont get me wrong to me it runs better than i thought a cammed and intake 346 should run. 7.62 in the 1/8 and 12.05 in the 1/4 in a 3400 lb. firebird. it seams to run out of steam around 1000 ft. mark just want pull no more. after the holley ls fest want to find someone that knows ls motors, to see if they can get anymore out of her.
Old Nov 9, 2011 | 05:34 PM
  #251
CETAWS6's Avatar
https://ls1tech.com/forums/dynamomet...-427-ceta.html
