Got my LS3 427 today!!
Old Aug 22, 2010 | 12:25 AM
  #41
Ellsworth's Avatar
you adding any spray just for track purposes?
Old Aug 22, 2010 | 12:40 AM
  #42
CETAWS6's Avatar
I don't know.
Old Aug 22, 2010 | 09:13 AM
  #43
The Alchemist's Avatar
UNDER PRESSURE MOD
Originally Posted by Big_Bird_WS6
^^^^ love the motor. can say i agree with the knock sensor location. lets just say he ever put PAS kit on there. it wont work. i always thoguht they werent down by the pan. but each there own. Just me 2 cents
I'm a little confused by your post. Do you agree with the knock sensor location or not? Did you forget the " 't" and what is the PAS kit?
Original poster, the motor looks good. Good luck with the build, looks great.
Old Aug 22, 2010 | 09:27 AM
  #44
CETAWS6's Avatar
Thanks man, I appreciate it. Yea I agree, I'm a bit confused with that post too. What is a PAS kit? I dont know either.
Old Aug 22, 2010 | 09:34 AM
  #45
Big_Bird_WS6's Avatar
sorry. my bad. the APS kit. and no i do NOT agree with knock sensor location.
Old Aug 22, 2010 | 10:12 AM
  #46
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
4.068 x 4.100
The claim that most 427s are 4.125 x 4.00 is not correct unless you are talking about LS7s. Most stroker 427s are exactly what this one is. The alternative is a sleeved LS2 block which is a great option as well, but more $.
BTW, if his headers clear the knock sensors where they are, there is absolutely nothing wrong with them. If they don't clear, you drill out and tap the lower hole where the stock LS2 sensors would go.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Aug 22, 2010 | 10:19 AM
  #47
UNDER PRESSURE MOD
Well, the gen 4 blocks don't have provisions in the valley anymore for knock sensors, so you either have to run them down low like that or not at all, unless there's another option I'm missing.
I don't think there's much concern about the APS kit either considering they have been MIA for quite some time now. There's always concessions with any build, it looks like the original poster didn't have to make many.
Old Aug 22, 2010 | 10:59 AM
  #48
CETAWS6's Avatar
Originally Posted by Scoggin Dickey
4.068 x 4.100
I had these SLP headers for almost about 2 years. Hopefully, they clear but if not, I make sure the above mentioned will get done.
Old Aug 22, 2010 | 11:29 AM
  #49
WKMCD's Avatar
Surprisingly, I don't think the location of the knock sensors is all that critical. I ran them off the back of the heads at one point and they worked fine.
They are now on the sides of the block and function exactly the same.
Old Aug 22, 2010 | 11:40 AM
  #50
CETAWS6's Avatar
Yea i didn't think it would be a problem. I'm kinda thinking about that 10 bolt I have. When I first did gear swap mod, I got the richmond install kit and a TA girdle with stud kit. So I got this 10 bolt setup the best way I could without dumping alot of money into it. Maybe it should hold up for awhile. Sometimes I use MT drag radials but no slicks. I dont beat up and race my car at the track. In fact, prior to this build I took my car to the track twice. It ran 12.5s consistently. Maybe the 10 bolt will hold up maybe not. I think I will go with a driveshaft safety loop just in case.
Old Aug 22, 2010 | 11:52 AM
  #51
XxXTransAmXxX's Avatar
Killer lookin motor!!
Old Aug 22, 2010 | 11:56 AM
  #52
MYSTIC-1SC's Avatar
damn that looks good.
Old Aug 22, 2010 | 12:07 PM
  #53
CETAWS6's Avatar
Thanks guys. Them guys at Scoggins made it possible.
Old Aug 22, 2010 | 12:16 PM
  #54
gm02ceta's Avatar
Wow that ceta should scream! I'm envious.
And just for a clarification CETA usually stands for Collector Edition Trans Am not Commemorate Edition.
Old Aug 22, 2010 | 12:24 PM
  #55
MonmouthCtyLS7's Avatar
A thing of beauty
Old Aug 22, 2010 | 01:26 PM
  #56
4.068 x 4.100
well i have never seen a 427 his why. just like you siad to resleeve.
correct the location should be fine. but again in the last 5 years of being on this forum i have only seen them in the stock LS2 location.
yes Alchemist, i know they cant go in the valley anymore. lol. i have a LS3 block. mine are drilled and tapped in the LS2 location. they need to get it so LS1 computers work with the stock LS2 style. they are small. lol.
and APS hasnt been on the forum. doesnt mean they are gone. hell APS still sells kits. they still have like 50 F-body kits for sale.
Old Aug 22, 2010 | 02:33 PM
  #57
UNDER PRESSURE MOD
My bad, hence why I said I wasn't certain. I didn't realize that there were two different locations on the bottom of the block to install them.
As for the APS kits, I know that there were quite a few unhappy people here with cooked turbos from APS and they stopped giving customer support saying they were no longer making them. I didn't realize that they still had 50 kits they were looking to sell.
You learn something new every day, hence why I browse this section every day. I'm about a year out on my gen 4 400+ cube build, so I want to learn as much as I can before I pull the trigger.
Old Aug 22, 2010 | 02:41 PM
  #58
CETAWS6's Avatar
Well I have no intention of running turbo anyways. Just pure NA terror. So u gonna get a gen IV 400 plus stroker? What CI u want to get?
Old Aug 22, 2010 | 09:22 PM
  #59
TransWS6Am's Avatar
dont expect that 10 bolt to last long at all, my 10 bolt lasted just past the break in of my 416 LS3. might wanna get one on order if u got the money for it. Great looking motor man! I can't wait to see numbers. And where are u located at? i saw u said u where close to summit.
Old Aug 22, 2010 | 09:29 PM
  #60
TransWS6Am's Avatar
oh if you have problems with the knock sensor clearing you can run the ls3 knock sensor racetronix sells the adapter/extension harness to run ls3 knock sensors on a ls1 harness,
