Crooked Rocker Arm?
Old Oct 4, 2010 | 09:46 AM
jbVHO's Avatar
Default Crooked Rocker Arm?
I had the valve cover off the passenger side of my LY6 this weekend, and noticed that one of the rocker arms seemed crooked (the middle one in the first picture). My question is will this be ok to run as it is, or is it severe enough that I need to adjust it? I assume that I am the first person to remove the valve cover and so it must have come this way, which also means that the motor has run about 7000 miles with it this way.
Any info is appreciated. Thanks.
From front of head
From back of head
Old Oct 4, 2010 | 10:23 AM
dimetweaker's Avatar
does that picture make it look like someone did some griding on there or does it looks as bad in person too? I mean maybe thats normal but I never noticed that on the 32 stock rockers those I have... maybe i just need to go look
Old Oct 4, 2010 | 10:52 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
Thats not grinding...thats a paint mark.
Have you tried tightening the bolt down? I would take the stand off and make sure that pedestal is in line with the rest.
Old Oct 4, 2010 | 11:30 AM
vettenuts's Avatar
I would try another stand as well unless there is something physically wrong with that particular rocker.
Old Oct 4, 2010 | 11:33 AM
jbVHO's Avatar
I didn't try messing with the bolt, but I did try to twist the rocker itself to check if it was loose and it wasn't loose at all.
Old Oct 4, 2010 | 01:04 PM
OUTLAWZ RACING's Avatar
Check the push rod.
Old Oct 4, 2010 | 01:05 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Well the bolt will allow the rocker to get tight, but until you torque it down, it will not align the rocker until it sits directly in the U channel.
Old Oct 4, 2010 | 02:42 PM
Marshessn's Avatar
AFAIK, this happens when something is not installed correctly or properly.
I purchased an engine from a shop here in houston, only to find out that all the engine work was done half ***. One head was stock and one had been apart at some point in time. The shop had assembled the head with impact guns and didn't bother to align the rockers. 3 out of 8 were exactly how you show in your picture. I simply replaced the stand underneath the rockers and assembled with care. They will still try to move upon assembly due to the bolt being twisted.
If anyone could chime in on how this could affect the rocker/valve wear patterns... or provide a better reason to how and why this occurred in his situation... I don't know the extent of "damage" that could be done by this misalignment. I don't see a lot of threads on it.
Old Oct 4, 2010 | 02:52 PM
Neumonic2002's Avatar
I have seen this several times, biggest thing would be noise and wear.
Old Oct 4, 2010 | 03:58 PM
c6 batmobile's Avatar
Get it fixed. This can wear the end of the valve as well as the valve guide in the head. It wont happen right away but over time it will wear out.
Old Oct 4, 2010 | 07:20 PM
jbVHO's Avatar
Thanks for all the replies.
I got the motor from a parts yard to swap into my Nova so I don't know the exact history, but with 7xxx miles in a van I wouldn't expect anybody had torn into the motor before me, but then again I wouldn't think the factory would send it out like that either.
Anyway, so the consensus is that I need to adjust it straight? Also, I have read that the bolts need to be torqued to 22 lbs, is that correct?
Thanks
Old Oct 4, 2010 | 08:40 PM
Thanks
There may be a seat under the arm that needs to be replaced to make it go straight.
22lbs should be your pre-load.
This is how I did mine:
Mark the top of the vlv with a black marker. Install rocker arm torque to 22ft lb. Spin motor. Check were marker on top of vlv is missing from. If its dead center reinstall to 22 ft lb. If its towards the outside of the motor you need less torque if its toward the inside you need more torque.
Anyone correct me if you have a better procedure.
Old Oct 4, 2010 | 10:00 PM
camarols1's Avatar
*The LS engine family uses net lash rockers, so the only way to adjust the sweep of the rocker tip is to shim the rockers or pedestals.
As John at Scoggin suggested, the rocker bolt likely just backed out causing the rocker to drift from its centered position when properly seated in the pedestal. Hopefully no thread damage has been done.
Just bump the motor over till the affected cylinder has that valve fully closed so the load is off of the rocker, then remove it and check for unusual wear. If it looks ok, reassemble and as you hand tighten the rocker it should self-align when seated against the pedestal.
Torque the bolt to 22 ft/lbs and you're good to go.
If the rocker or pedestal look worn I would replace them, especially since both items are stupid cheap.
DO NOT run the engine until this is fixed.
Good Luck!
Jim
Old Oct 5, 2010 | 09:10 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
22lbs is the TQ spec. You can't change the wipe pattern by varying the Tq to which you tighten the bolt.
Preload is how much the pushrod pushed down the lifter cup after 0 lash.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Oct 5, 2010 | 09:15 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
Good Luck!
Jim
^ What he said!
You are completely wrong. More torque and less torque? That does not make any sense. If the wipe pattern is wrong on a stock setup, something is wrong. Since the rocker arms are EXTREMELY important, why would you torque the bolt down to less than specified?
Also there is no seat under a stock rocker arm that can be adjusted on a stock setup. The entire stand has individual pedestals on them that align the rocker and provide the proper seat height for them. The stand and the pedestal are one piece. No adjustment there. You can shim the stands, but you would not have that option on an all stock engine, nor should it need it.
Have you looked at a rocker stand?
Old Oct 5, 2010 | 07:08 PM
jbVHO's Avatar
Thank you all for the helpful information
Old Oct 29, 2010 | 06:42 PM
jbVHO's Avatar
Alright, I finally got around to fixing this, and I was just checking out the other rockers, and just a couple look slightly off center as well. None near as bad as the one pictured above, and I probably won't worry with fixing them, but I was just curious if GM sends them out this way? Would that be within their tolerances?
Old Nov 12, 2010 | 08:15 PM
jbVHO's Avatar
Going to try to bump this up...
Just wondering what an acceptable position is for the tip of the rocker arm (say, in relation to the valve stem, or valve lock, etc.)?
For example, a different arm is off center an amount to where when looking from above, the arm tip covers up the far left edge of the valve lock. Like the first or second picture, just not quite as bad (it covers the entire valve stem).
Thanks
Old Nov 12, 2010 | 08:56 PM
SilverSS's Avatar
That's a bad rocker stand man. The rockers should line up with the valve tip he same as all others. What did you do to fix it?
Old Nov 12, 2010 | 10:50 PM
DietCoke's Avatar
The rockers DO sweep across the trip of the valve left to right (normal), that one just looks like it was installed incorrectly and has an alignment issue.
