L92 heads on a 5.3?
Old 12-30-2010, 06:28 AM
boosteds10's Avatar
Default L92 heads on a 5.3?
Will L92 heads work on a 5.3?
Old 12-30-2010, 06:52 AM
Slamdsdime's Avatar
L92 heads, due to their rather large intake valve, require at least a 4.00" bore to be utilized. Roughly speaking, they'll fit on a stock bore 6.0l, and larger, bores.
Old 12-30-2010, 06:53 AM
DeadOnWS6's Avatar
no, you need atleast a 4.00" bore.
Old 12-30-2010, 10:13 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Like these guys have posted you will need at least a 4.00" bore to run the L92 heads.
Old 12-30-2010, 11:12 AM
BES Stroked Nova's Avatar
GMPP just released a set of 3.905" bore L92 heads. might check into them and see just how small of a bore they can fit on...
Old 12-30-2010, 01:46 PM
boosteds10's Avatar
Thanks for te info guys! Now my next ? is out of the "new" small bore L92s or the 317s, what would yall recomend for a 5.3 master power t70 on pump gas?
Old 12-30-2010, 02:21 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
In almost every sense of the word, those aren't L92 heads!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-30-2010, 06:29 PM
briancb1's Avatar
I just picked up a GMPP catalog today while on my lunch break, I didn't see any "small bore" rectangle port heads in there.
Old 12-30-2010, 10:09 PM
they are in there. not saying i have used them... just something to look into.
seemed like a l92 head with 2.00 valves.
Old 01-01-2011, 11:04 AM
boosteds10's Avatar
See thats the thing, its not going to be a N/A motor. It will be consuming air from a master power t70 at the tune of about 13# on pump gas.
Im just wondering if these heads are more trouble than they are worth, and if it should just stay with the original plan of using the 317s and a ls6 intake/tb and be done with it?
Old 01-01-2011, 06:03 PM
HCCH's Avatar
the GMPP catalog says the small bore l92 heads can be used on a minimum bore of 3.890". I haven't seen the head nor do I know the guide spacing but it doesn't sound like it would work on the 3.780" bore the 5.3 has.
Old 01-20-2015, 10:43 AM
DjohnsonFTW's Avatar
was there any update on this? did anyone ever find out if the small bore heads would work? im very interested in trying to get the rectangle port onto my 4.8 so I can put a LSA supercharger on it.
-THanks
Dane
Quick Reply: L92 heads on a 5.3?
