LQ4 build what kind of RWHP??
i would really like to see 500rwhp but probably wont happen but would be happy with close to 475-480 N/A. what do u guys think?
-Fresh LQ4 shortblock W/ ARP's
-polluter cam (24x,24x dur & 610,612 lift)
-ported 799 heads
-LS6 intake
-thinner head gasket to up the compression a little (not sure which gastket to use... any suggestions??)
its a 6spd car with a 10 bolt for right now with 4:10s
let me know what you guys think it might put down N/A and also with 150 shot also any suggestions on what to do to get to the power range im lookng for w/o sinking to much more money into this thing its just a street car weekend warrior
thanks
-ported 799 heads
-LS6 intake
thanks
-ported 799 heads
-LS6 intake
thanks
-ported 799 heads
-LS6 intake
thanks
my heads are milled to 63.5 cc and stock .052 gaskets I have 10.3/1 compression.
My trans am with mildly ported 241's made 452/422 with my lq4 short block and f14 cam.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Ok maybe someone can point me in the right direction, but i swear there was a thread or a Sticky for a LQ4/9, Ls2 swap in to a F-body. Is it the same as the L92/LS3/L76?
-ported 799 heads
-LS6 intake
thanks
-ported 799 heads
-LS6 intake
thanks
stock lq4 with stock crank
6.125 rods
wiseco pistons high compression pistons (should be around 13.3:1)
.040 head gaskets
sdpc cnc ls3 heads
patg custom cam
gmpp single plane carb intake
i am sure i am forgetting some things
I think with somone like advanced Induction or TEA porting those heads, the polluter cam and .040 gaskets Aiming for 11.1 compression you could get 475 or so with a ported fast intake. but 450 + with ls6.
with a 12 bolt and 4.11 gears on 17 inch rims
also i havent takin the block in to get worked and been juggling the idea of .030 over to make it a 370 i think that might help me out a bit plus running the 11.5:1 compression
You could get some -4 cc pistons with deep eye brows for vavle relief and mill the heads to around 59 cc. at .o30 over bore would get you about 11.24/1 with a .045 gasket and 11.05 with a stock .052 gasket. 11.39/1 with a .040 gasket
For refference, Im running Mahle power pac pistons with 4 cc reliefs and 5.3 heads milled to 54 cc chambers and 2.0 int. valves, 1.6 exhaust and have **** loads of clearence with a 238/250 .603/.596 110lsa 106 cl cam.
awesome im new at all this head work talk, its kinda confusing haha i need to get on here and do some homework so i can figure all this stuff out cuz im about to get started on the build and all these different piston styles and sizes
to many numbers all at once!!! haha
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
