LS2 Rod replacment
Old Dec 26, 2011 | 08:28 PM
3rdCoastPowerSports's Avatar
Default LS2 Rod replacment
Putting new rods into an LS2 motor due to a spun bearing. The crank will need to be machined... What aftermarket rods anyone recommend? this is just going to be a mild 224 cam build. I would like something as strong or stronger than stock and has a good price point.
Old Dec 27, 2011 | 08:09 AM
redtan's Avatar
Callies compstar, or maybe K1 or Eagle depending on your budget. All those can be had for under $600 (under $500 for the Eagles) and are all stronger than stock and will be more than ok for the mild build you're doing.
Old Dec 27, 2011 | 04:35 PM
JPH's Avatar
JPH
How much power are you wanting to make now?
Old Dec 27, 2011 | 04:45 PM
KCS's Avatar
KCS
Moderator
SCAT I beams are probably the best bang for the buck. They're less than $350.
Old Dec 27, 2011 | 09:14 PM
should be around 410 or so to the rear wheels, at least that's the current plan. might be spraying it later so i need the rods to stand up to that
Old Dec 28, 2011 | 12:09 PM
JPH's Avatar
JPH
A stock con rod with an ARP bolt upgrade will work plenty fine for now. An aftermarket H-beam style rods are getting cheaper and would be a good long term investment as well. But not to many people will go that route without putting a better piston/ring package on at the same time to.
Old Dec 28, 2011 | 12:41 PM
new ARP bolts are for sure as well as new piston rings. if i change rods do i need new pistons? or as long as i use stock length rods can i reuse my stock pistons?
Last edited by 3rdCoastPowerSports; Dec 28, 2011 at 12:49 PM. Reason: wrong thread
Old Dec 28, 2011 | 02:43 PM
JPH's Avatar
JPH
Ok great. No not necessarily. Yes, depending length and pin size.
Old Dec 29, 2011 | 05:36 AM
LS1MCSS's Avatar
Before ordering just rods, make sure the piston pin size is correct. Most aftermarket rods will have a different size from stock.
Old Dec 29, 2011 | 07:39 PM
good looking out. I believe scat makes I beams for stock stroke and stock pistons (6.098" rods, .945" Pin). any recommendations on Rings?
Old Dec 30, 2011 | 07:12 AM
A_VAS's Avatar
Callies Compstar p/n CSC6100DS6A2AH
stock length 6.100 (basically), stock pin size
I used these on a stock crank LS2 and very happy. $436 if you call Callies direct, these are listed as 'overstock' so the price is good
