Cam Motion Low Lash Solid roller FRH LS3 ported heads 542whp/484wtq
#221
#222
#223
Well my Mast valvecovers showed up yesterday. Unfortunately they forgot the bolts, and no one around me carries any m6 hardware. Well, Fastenal does, but they're closed on weekends. Mast apologized and sent them out right then and there. People make mistakes. As long as they're willing to fix it that's all I can ask for.
I fortunately don't have any plans this weekend. This weekend is pretty much dedicated to working on the car. I had ordered some shims from Jesel last weekend because the more I looked at the wipe, the less I liked it. Had I gotten. The hardware in yesterday, I probably would've left the geometry as is.
Top left is no shim
Top right is .032 shim
Bottom is .050 shim. I think it's pretty much dead on. Unfortunately now I'll need a slightly longer pushrod. I'm not sure if Manton takes returns at all. I doubt it. So if anyone needs a 11/32 .120 pushrod with tool steel tips 7.300 let me know. I'll cut you a good deal.
Top left is no shim
#225
#228
#229
#230
Under the stands. It moved the wipe toward the center of the valve and narrowed it as well. Likely would have been dead on prior to the head work.
#232
Found a good deal on a FAST 102/NW 102 setup. I know they're generally not great for gains as far as the ls3 is concerned, but I was thinking about picking it up because of the price. Maybe send it off to Chris Frank to have him port it or Tony Mamo even.
Thoughts?
Thoughts?
#233
From: Coast of San Mateo County Between Pacifica & HMB
I would absolutely have Tony port your Fast 102! He ported
My Fast 92 & LS2 TB for my bolt on C5 about 7 years ago,
Great Results!, As well as a Fast 102 for my
TFS LS3 CAMMOTION LLSR Big Bore Build!
I don't think anyone has ported more or Better Fast Intakes.
Hopefully the Fast Medium & Race Runners will
Be available soon (1-3 Months) to fully take advantage of the
LLSR & Flow of the TFS LS3 Heads!
Contact Tony you will be pleased with the results!
Guaranteed, I Promise!
#236
I sent my FAST 102 to FRH along with my heads to be ported. I figured they're the heads, might as well have them port the intake also. God I can't wait to get everything back haha
#240
The carb style intakes are nice, but not really what I had in mind for the car right now. If I do decide to go that route I'll need a big cowl to fit it. Looks like I'll be staying stock intake manifold for now. Couldn't get my buddy to meet with the guy locally to get it because he's out of town.
Maybe I'll just buy some Kinslers. Lol. Jk.
