The Pontiacolypse
Put a TB Spacer on to get the blade to 100% throttle. Compared to 76% before being all I could get on the new intake. But I forgot to hook up IAT. The WB error was showing 10% error due to not hooking up IAT, so the data below needs to be adjusted by 10%...
Maxed out g/sec again. Around 6500 rpm, it held until 7100 when I let off.
G/cyl went from 0.99 to 1.20. Remember this is scaled 25%.
Injector duty cycle went from 98.4% to 120.2%
At 7k, which looks like peak power, the WB was showing 0.9 lambda, but IAT was disconnected, so it might have actually gone lean. Honestly not sure how to interpret this other than I had calculated my injectors would be enough but they are apparently not.
So I need 60 lb injectors for real. And I need a new pair of shorts. Had LazerLemonTA in car with me, spun second (typical), hooked third at 45 mph and pulled to 106. It covered that in a very short distance. Both of us scared shitless. *** shaped creases in the seats now btw.
From 45 to 107 in third gear pull in 4.89 sec. but not in powerband until 78 mph where a track upshift would be. From 78 to 107 in third was 2.41 sec.
This is a size I fit often.
They WILL BE Flow Matched, set of eight, with Dead Times report.
Can your "spec" the Injection Instant in degrees ?
You will get best price.
Lance
Like I said, we've done 50% before on the stock ECU without a problem. Edit - I made a post in DDN's thread on scaling the tune with my observations to see what people who know more than me think.
bottom line, I think that the car is running better scaled vs unscaled.
Good catch on the timing scaling as you CAN blow stuff up, especially when boosted, if you don't pay attention to your new g/cyl. I briefly mention this in the sticky and it is an important note. I'm glad you confirmed my discussion on the idle tables. I had some that I scaled half of the rest of the tune and some that I didnt scale at all. Seems like it is setup dependent. Glad its running better!
