The Pontiacolypse
Old Mar 12, 2018 | 10:53 AM
  #81
pantera_efi's Avatar
Default Engine Lease Warrenty
Hi Jake, I believe you are here to help members as am I.
The information question : Many Racing Engines are Leased with extra charges for improper operation. The operational methods ARE listed in the engine contract. I am not sure this is public knowledge, may be protected data.
My ECU has data logging AS do most engine controllers with switch on recording stored in Flash, protected Flash.
Thus Oil Temps, Water Temps, RPMs are STORED with a Time Stamp.
The cost of this type of contract is over 100K, who would not follow the instructions ?
I follow Jake's instructions at a MUCH LOWER cost, do you ?
Lance
Old Mar 12, 2018 | 11:10 AM
  #82
Darth_V8r's Avatar
Moderator
Its funny but my break in method was more of an accident.
First motor swap I ever did. I had forgot to hook up the alternator and a vacuum line, so it started, idled up, settled down, died with this god awful shrieking noise, so I thought the motor had locked up. I was pissed so I walked away hour later, I turned the key and the motor cranked, so I was like "yes!" I started it again and it did the same thing. Then I realized what it was, so I let it cool and connected the missing stuff. Then I started it up and let it get good and warm idling and changed the oil. Then after letting it cool, I took it out and left it in second gear and pulled 20-50 mph at 3/4 throttle and coasted down in gear. Did this about twenty times. Mainly just to load up and seatvthe rings real good. Changed oil again and just drove it. Oil changes at 500, 2000, 5000.
Later on when talking to someone about it they said that was a text book break in. So that's just how I do them now.
Old Mar 12, 2018 | 12:25 PM
  #83
ddnspider's Avatar
That's what I want. Where is this textbook lol.
Old Mar 12, 2018 | 12:44 PM
  #84
Darth_V8r's Avatar
Moderator
You know I never thought to ask...
Old Mar 15, 2018 | 12:50 PM
  #85
Darth_V8r's Avatar
Moderator
Well, here is some work i've been able to do. Worked the idle down to about 875, good and stable, fine tuned return to idle, and did some work off idle. I can't really do too much more until I get it rolling and can get some load on the engine, but this thing is really falling into place nicely.
Here's a short 30-second vid with some throttle stabs and return to idle. I'm really happy with it. Just getting more antsy to drive it.
File Type: mov
Old Mar 15, 2018 | 09:30 PM
  #86
big hammer's Avatar
This motors nickname is “Horse ****”. Similar to what ford does with their engine names like coyote. We’re not sure if Darth likes the name at this point, but that’s it’s name
Old Mar 15, 2018 | 09:36 PM
  #87
ChopperDoc's Avatar
That's the trouble with nicknames... Normally they are "assigned", not picked... lol
Old Mar 15, 2018 | 10:38 PM
  #88
You must have thought long and hard on that one.....
Old Mar 16, 2018 | 01:26 AM
  #89
ChopperDoc's Avatar
Long and hard.... lmao
Old Mar 16, 2018 | 09:49 AM
  #90
Darth_V8r's Avatar
Moderator
Horse **** Performance Cams - "for when a donkey dick cam just won't get 'er done"
Crap, it's gonna stick, isn't it?
Old Mar 16, 2018 | 10:04 AM
  #91
big hammer's Avatar
Horse **** cams—- nailing the competition
Old Mar 16, 2018 | 02:22 PM
  #92
You better believe it, baby!
Old Mar 16, 2018 | 02:27 PM
  #93
sixty9fordkiller's Avatar
lmao!!!
Old Mar 16, 2018 | 02:30 PM
  #94
From here out, ANYONE running a donkey dick cam shall be regarded as an underachiever.....
Old Mar 16, 2018 | 02:36 PM
  #95
hahaha. thanks fellas. i needed a good line for my signature and you have provided just that
Old Mar 16, 2018 | 02:38 PM
  #96
Darth_V8r's Avatar
Moderator
Guess it's better than horse vagina -- loose and sloppy engines are our thing
Old Mar 16, 2018 | 02:41 PM
  #97
that engine would be The Mule. Got both horse **** and donkey dick in it
Old Mar 16, 2018 | 04:32 PM
  #98
big hammer's Avatar
Proud to have a Horse **** Cam in my motor. Coming soon to a thing near you
Attached Thumbnails The Pontiacolypse-d2e8b8eb-f052-4d0a-a431-fec5aa323800.jpeg
Old Mar 16, 2018 | 04:34 PM
  #99
spanks13's Avatar
Not recommended to insert dry
Old Mar 16, 2018 | 04:42 PM
  #100
ill have a llsr soon and ill have a horse **** then as well
