LS7 Head Valve Guides
So, my question -- Has the aftermarket corrected the issue? In other words, if one purchases aftermarket LS7 heads that are also aftermarket castings, has the error been corrected? Or, were the heads reverse engineered around the error, so it has been copied forward into all the aftermarket versions of the LS7 head?
it would be a terrible shame if this did happen, as the head is a very forward looking design in its day.
I had Sheldon install my Induction Hardened Steel Guides using his Serdi Machine AND machine the seats.
The Serdi "centers" on the guide with seats cut concentric.
I assemble the head myself AND use Titanium Dioxide (tooth past) to mark seat angle.
I have found errors, not often, with "rework" required.
I do not "lap" seats with SAND.
I do not know why the "truck" head would be different than ANY OTHER cylinder head ?
Lance
The run-out can be easily corrected through proper machining of the valve seats, weather using a pilot or a CNC machine.
The increased wear mentioned by z0sicktanner has nothing to do with the dimensional design/layout of the head (factory or aftermarket) and has everything to do with the quality of the machining, application usage, component material, etc. Increased wear will be present when using today's aggressive camshafts, valve springs, etc.
I think one of the biggest contributors to LS7 valve guide wear is the fact that a lot of people run more aggressive camshafts (me included) with stock rocker arms that have additional "scrubbing" across the valve tip which directly contributes to increased valve guide wear. Using a roller tipped rocker arm can help the situation if the geometry is properly setup.
Do I EXPECT my guides to last 100K miles, no. Do I need to check them more often because it is a "performance" engine, yes.
I agree. Regardless of cylinder head type or manufacturer, valve seat run-out applies to all.
As much as valve lift is a factor, so to is the design of the cam lobe on the overall general wear of the valvetrain. An aggressive lobe on top of high lifts (which for an LS7 is generally > .650") will wreak havoc on any LS motor in general, and in particular an LS7 valvetrain. If you look at the COPO cars for 2018, I think they have a good recipe going: Johnson hydraulic lifters, PSI valve springs, and a CamMotion camshaft. Of course, they're still using Ti valves on PM guides which is generally not the preferred solution when using Ti valves. And if that head was machined by Linamar (like every other GM LS7 cylinder head) then there is a good chance those guides (or at least one, and all it takes is one,) are not concentric.
The closest one can likely get to a sure-fire solution to the LS7 valve guide issue is a proper concentric valve job using a superior exotic alloy like CuBe, or even better Moldstar. AHP has taken the time to craft an LS7 valve guide out of Moldstar 90 and it has the best of both worlds in terms of thermal conductivity and hardness/durability.
http://moldstar.com/MotorsportApplications.htm
now elevate the lobe flank speed, overall valve lift, and rpms.......seems like the perfect storm to EFF’d up ****
These engines are OFTEN "freshened".
I found MANY cures NEEDED to increase engine life in the Oil Field/Natural Gas Engine.
We fit Stellite Faced Valves/Stellite Seats AND Steel Guides in this type of application
Stellite works very well in high heat engines.
The choice is mandated by the users expected engine life, time between rebuilds.
Lance
