418 Build N/A High Compression
New motor specs
4.08 JE pistons 2.77 CC Dome
K1 4 inch Crank
K1 Rods
Trick Flow 255 Heads with hollow intake valves
Crower shaft rockers
Cam Motion Cam Solid Roller 255Intake 271Exhaust
Sheet Metal 102mm intake
2inch Headers
3 inch dual exhaust
13.7:1 Compression Ratio
Then, right before we were going to order the steel beam to knock out the wall, discovered a water leak which turned out to be a failed shower surround. Removed shower mold everywhere.
Couple that with 85%+ travel.
Short answer, no idea. I do know I will do heads first. The car is driving nice and right now that's what I need out of it. I am working with a guy who is doing his ITB so maybe we will both know something whenever he is ready to reveal
I understand completely. We moved last year which is why it has taken so long to get back to building it.
I am thinking about getting a holley high ram and shortening the runners for hood clearance. Not sure though.
Also I am trying to figure out whether it is worth having the heads ported more. The trick flows are pretty good from the factory but mamo says he can get another 10-15cfm s out of them.
A lot of what you see is the intakes homogenizing heads. So it's actually better to spend more on a better intake than worry about trying to extract another 5-10cfm from the heads. Though, the better the head, the more it pulls through the intake. But it's cheaper to port an intake than fondle heads hoping for another 3HP.
With a 4" stroke I think you're going to be finding the limit of the 255cc intake port.
