LSX 454 freshen up
Old 01-25-2020 | 06:57 AM
  #181
Mickyinks's Avatar
Priority mains.. Oil pressure is pegged. standard volume high pressure. Im thinking of dropping the new low volume pump in.
Ill see where power starts to drop and set limiter 300rpm higher
Old 01-25-2020 | 07:00 AM
  #182
bortous's Avatar
dry sump set up is expensive as hell too.
I would definitely say you need it at 8000rpm.
Old 01-25-2020 | 07:13 AM
  #183
Darth_V8r's Avatar
Moderator
Priority mains ftmfw. I setvlimiter way high. I made peak at 7k on previous motor. Limiter at 8k
Old 01-25-2020 | 07:28 AM
  #184
Mickyinks's Avatar
Maybe im being a bit cautious then. 1st solid roller v8 ive had, used to the hyd going 6800rpm.
Im not going to rev it for the sake of it and it spins up easy as it is.
I just took my daughters friend for a squirt and had wheel spin 1st ,2nd,3rd and into 4th with 7000rpm shifts
The following users liked this post:
Che70velle (01-25-2020)
Old 01-25-2020 | 07:37 AM
  #185
Mickyinks's Avatar
Just realised i will have external oil pump that i can set pressures on with the dry sump set up
Old 01-25-2020 | 07:38 AM
  #186
bortous's Avatar
I really want to go for a spin too.
I forget is your car manual?
Old 01-25-2020 | 07:43 AM
  #187
98_WS6_M6's Avatar
Typically you want to shift far enough past peak so you drop back into peak power. If you shift at peak power you'll fall back into an rpm range where it will slow you down.
Old 01-25-2020 | 08:16 AM
  #188
AINT SKEERED's Avatar
Priority mains on my dart and turn 7900 almost every drive, wet sump and good oil pressure when done. Peak is 7600 ish so I go higher to not fall so low
Old 01-25-2020 | 08:23 AM
  #189
Launch's Avatar
Even on my current heap of sh*t cam-only 346 I found it will et quicker on my gtech every time when I shift at 7400-7500 rpm than if I shift at a lower rpm. And the cam isn't even that large. Limiter set to 8k so I never hit it by mistake but I have hit 8k a few times. I've spent almost nothing on that engine so I don't care.
Back in the early days of LS's a lot of us were too afraid to rpm even just cammed or head/cammed sbe cars too high because the cars and engines were new to us and expensive to replace back then. Now we realize we can spin junkyard stuff to 8k because the engine didn't cost much so we tested the waters.
If you're not drag racing or trying to achieve the best 1/4 mile ET, and have more HP than you need or your car can put to the ground, then it's not worth spinning so high past peak power unless just for the fun factor. Not worth it for the OP's build, as I imagine his mid range power/torque alone would overtake most cars on the road like they're parked still.
Old 01-25-2020 | 08:27 AM
  #190
Darth_V8r's Avatar
Moderator
My comment was really for racing. Power past peak is an often untapped gold mine at the track. Street driving, 8k gets you noticed from a mile away
Old 01-25-2020 | 08:34 AM
  #191
8000 get all the attention. I love it🤩
Old 01-25-2020 | 09:39 AM
  #192
98_WS6_M6's Avatar
Yeah I guess I wasn't being clear either. I didn't mean you have to shift like that all the time. That's more for racing. But if you're ever going to race or just beat the crap out of the car I'd set my limiter quite a bit past peak. It's just a safety. If you money shift it's not going to help anyway lol
Old 01-27-2020 | 01:55 AM
  #193
Mickyinks's Avatar
Ok Limiter is set at 8000rpm
Was pulled over by the cops yesterday. To low and said my new tyres arn't legal. Argued with him but he wouldnt budge. So now need raise height and new tyres for road worthy certificate
Driving home was just bout home and sprung a leak from oil cooler somewhere, oil temps fine , pressure fine, just a line of oil about a kilometre long... Other than that 300miles and didnt miss a beat...
Anytime Bortous
Old 01-27-2020 | 02:16 AM
  #194
bortous's Avatar
Anytime Bortous
When you got pulled over did the cop question your exhaust noise?
What was illegal about your tyres?
That oil leak would **** me off.
Old 01-27-2020 | 03:48 AM
  #195
Mickyinks's Avatar
They asked me to start the car and they listened to the exhaust. Said it was all good... I Love my Varex hahaha
Nothing is illegal about them michelin sport cup 2 semi slick... Still plenty on the depth gauge... Wouldnt listen at all, pulled receipt out they only 7 weeks old
Need new oil coller ,sprung a leak
Old 01-27-2020 | 04:08 AM
  #196
bortous's Avatar
They let you off with the exhaust?
That's awesome.
They are pretty strict with the ride height though.
When my vz was checked years ago it was just on legal.
I wonder if they checked the load rating of the tyre too.
​​Was the oil cooler faulty?
Old 01-27-2020 | 04:32 AM
  #197
Mickyinks's Avatar
I have 3inch cat back hollowed out cats varex mufflers... When they asked me to start it i pushed the button and the varex mufflers went into super quiet mode.. If i have em open its super load .
No load rating check, said not enough tread, ..Told him they semi slicks and thats how they are, check depth indicator. Wouldnt listen
oil cooler cracked ...
Old 01-27-2020 | 05:59 AM
  #198
bortous's Avatar
I have been looking at fitting those mufflers too.
There will come a day when I will get checked.
Do you know if those varax mufflers are also compatible with the vt-vz chassis?
Old 01-27-2020 | 06:08 AM
  #199
Mickyinks's Avatar
You can buy them for most models, saved my *** plenty of times. Definitely worth the coin
G Atsma (01-27-2020)
Old 02-06-2020 | 08:41 PM
  #200
Mickyinks's Avatar
A set of new rear tyres, raised the car by an inch, new B&M engine oil cooler, a road worthy certificate and im back on the road.......
Quick Reply: LSX 454 freshen up
