LSX 454 freshen up
Old 06-26-2020, 07:18 AM
  #481
Moderator
Darth_V8r's Avatar
Received 1,852 Likes on 1,152 Posts
Originally Posted by Mickyinks
Im trying to calculate the cc of my piston. If im correct cc's are cubic centimeters So if i measure depth of dish and depth of valve reliefs and work out the cubic centimeters that is my CC's
Am i correct in this method???
You are correct. it might be easier to do i the way they do cylinder heads, though, if the pistons are not domed.
Old 06-26-2020, 07:28 AM
  #482
Mickyinks's Avatar
https://www.youtube.com/watch?v=0R8d1eS8A8U
Thanks Darth, I have a small dish and valve reliefs and something didnt seem correct about the engine builders claim they were -5cc when the same piston but flat top shows -5cc
My pistons are -7.5 cc actually so the way the engine was built it had 11.4 : 1 scr and a 7.98 : 1 dcr
Ill end up with 12.17 : 1 with the head gaskets ive ordered and thatll take my dcr to 8.63 : 1
Could i do better?
Old 06-26-2020, 07:46 AM
  #483
Moderator
Darth_V8r's Avatar
Could i do better?
I don't know your fuels as well as US fuels. If it were US 93, i'd say take it up until your DCR is 8.72, likely right at 12.3 static.
Old 06-26-2020, 07:50 AM
  #484
Mickyinks's Avatar
Our ratings different to yours , i use 98 but thats the same as your 93... My quench is at .036 with the .038 head gaskets , would i go thinner head gasket?
Old 06-26-2020, 09:55 AM
  #485
Moderator
Darth_V8r's Avatar
No, don't go thinner. Your right where you want to be for quench. Just send it.
Old 06-26-2020, 07:35 PM
  #486
Mickyinks's Avatar
will do thanks...
being an iron block it'll generate more heat so I'm happy with it being a tad less scr/dcr. I'll have flex fuel sensor ser up so have some back up.
Im hoping with new cam and higher comp I'll pick up the 8rwhp I need to hit my goal and car should have a lot better torque curve.
my prediction is 30rwhp/25ftlb
Old 06-27-2020, 04:05 AM
  #487
bortous's Avatar
I expect a great torque curve too with the new adjustments.
What you will notice though is how much quieter cam motions low lash solids are.
The 5 minutes I heard mine I was super impressed.
Old 06-30-2020, 06:04 PM
  #488
Mickyinks's Avatar
Can anyone tell me what the lobe lift is for a cam motion low lash solid??
Old 06-30-2020, 06:33 PM
  #489
Moderator
Darth_V8r's Avatar
It varies based on what is requested. Just like hydraulic lobes. Maybe I am not understanding the question the way it is intended?
Old 06-30-2020, 06:38 PM
  #490
Mickyinks's Avatar
im asking due to the 1209 springs I have will accept .710 max lift . Any more and I'll need more spring.. will it be ok to keep under .710?
Old 06-30-2020, 08:01 PM
  #491
Moderator
Darth_V8r's Avatar
Yeah for sure. You can get it at about any lift you want
Old 06-30-2020, 08:09 PM
  #492
Mickyinks's Avatar
i found specs I'm getting 254/266 112.5+4.5 .704 .698 so I'm safe
Old 06-30-2020, 09:28 PM
  #493
Received 3,650 Likes on 2,230 Posts
Mick, I’m pretty sure 1209’s are good to .750” unless you’ve set them up at a different height?
Old 06-30-2020, 10:44 PM
  #494
spanks13's Avatar
You also have lash and deflection which will reduce lift vs nominal
Springs typically have a bunch more clearance to coil bind than the rated number too you just need to measure.
Old 07-01-2020, 12:40 AM
  #495
bortous's Avatar
Did you change cam specs again?
Old 07-01-2020, 03:22 AM
  #496
Mickyinks's Avatar
yep .... I was happy how it drove with last cam and it having 36 overlap, so I dropped lsa to get closer to dcr target and it'll be at 35 overlap...
Chevelle I had my head guy shim them to 190lb on the seat minimum. At that I can go max lift .710..
the lifters arrived today today after getting rebuilt, I'll have all parts tomorrow except for the cam.
im thinking I'll drop lifters in, heads on, lvalley plate and put it in the car or is that stupid idea? Just wait for cam and do it all at once?
The following users liked this post:
Che70velle (07-01-2020)
Old 07-01-2020, 08:07 AM
  #497
bortous's Avatar
That's good.
Still a cam motion right?
29 degrees of overlap warm is going to drive good in your 454.
You pretty much have same valve events as before except for more overlap.
I would wait for the camshaft and do it all at once.
When do you think it will all be back together?
Old 07-01-2020, 12:42 PM
  #498
Mickyinks's Avatar
That's good.
old cam ivo 18 ivc 60 evo 67 evc 17..... overlap 36 scr 11.30 dcr 7.93
new cam 19 55 71 16 35 12.10 8.63
Itll be in the car running about 10hrs after i get the cam.... I just need everything ready by november for the conrod straight sprint. So once engines in it'll be getting interior upholstered
Then off to suspension tuning/track set up guys another week ,they'll set suspension up and mount fire extinghuisers , tow hook, harnesses. My new flat underbody panels after that, camaro bonnet vent and ready to rock n roll . I think ill crack 187mph
Old 07-02-2020, 06:33 AM
  #499
bortous's Avatar
Looks good to me Mick,
Have you ordered the camshaft yet?
Old 07-02-2020, 06:54 AM
  #500
Moderator
Darth_V8r's Avatar
You're going to feel a massive kick in the shorts in the midrange from that DCR. Very nice work optimizing, sir.
Quick Reply: LSX 454 freshen up
