LSX 454 freshen up
Old 08-13-2020, 12:56 AM
  #541
bortous's Avatar
Originally Posted by Mickyinks
Turned the key and fired up straight away with good oil pressure. Doesnt sound any where near as grumpy. old cam 259/265 new 255/269
Only prob is i need to get new exhaust manifold gaskets
Good to hear all is good so far.
Having the right camshaft and less overlap would certainly make it sound tamer.
Keep us updated.
Old 08-15-2020, 07:16 AM
  #542
Mickyinks's Avatar
Spent the day street tuning and tidying up little things. All good so far
Link to video of exhaust note
https://1drv.ms/u/s!ArZo728_Mwe5t2Rf...nuzOG?e=82ozrU
The following users liked this post:
rkupon1 (08-15-2020)
Old 08-15-2020, 07:36 AM
  #543
bortous's Avatar
Oh yeah, She is sounding good.
Was that video taken after the street tuning?
Have you completed it yet?
Old 08-15-2020, 07:40 AM
  #544
Mickyinks's Avatar
About mid way thru tuning . Idle was good from the get go so havnt messed with idle .
Tomorrow ill give it the boot and see how it compares to last cam.. Im a happy camper so far.
Old 08-15-2020, 07:47 AM
  #545
ramairws6's Avatar
Like the trailer hitch on your "race car" lol
Old 08-15-2020, 07:48 AM
  #546
Moderator
Darth_V8r's Avatar
Received 1,852 Likes on 1,152 Posts
That's what makes it a sleeper.
Old 08-15-2020, 07:51 AM
  #547
Mickyinks's Avatar
I have a few acres out bush and tow a ride on mower there. Its awesome when you pull away from people at the lights and they realise im towing a trailer...
Old 08-15-2020, 07:54 AM
  #548
Mickyinks's Avatar
Also i didnt build it to look at, built it to drive , have nearly done 200,000miles , and i love driving it
Old 08-15-2020, 07:56 AM
  #549
bortous's Avatar
Yeah do that.
I'm interested in SOTP feel compared to before.
I wonder if it will accelerate harder compared to previous camshaft especially up too and how your low end torque is in 6th gear.
You did mention a while ago how you can get it so spin in 6th very easily.
Old 08-15-2020, 08:00 AM
  #550
ramairws6's Avatar
This is exactly why i'm laughing. Just imagining pulling up to a light and hearing that thing and there's a trailer of some sort hooked back there
Old 08-15-2020, 08:03 AM
  #551
Mickyinks's Avatar
Yeah do that.
I dont really think about torque because from 2000rpm it just goes nuts. An example was when it was wet and i was towing a trailer with mower , i was cruising at 1600rpm and when i started to accelerate it just lit up, i do run semi slicks but still to do that at 110kph , top gear, is nuts
Old 08-15-2020, 08:08 AM
  #552
Mickyinks's Avatar
Its even more fun when i get to the lights and have the varex mufflers set at quiet, then as i start pullin away open the exhaust fully and let it rip ...
Old 08-15-2020, 11:42 AM
  #553
ramairws6's Avatar
I have the same gig with the electric cutouts. Its pretty fun trippin' people out lol
Old 08-15-2020, 03:58 PM
  #554
rkupon1's Avatar
Thats a fine specimen of lsx choppin'
Old 08-15-2020, 05:50 PM
  #555
AINT SKEERED's Avatar
Car sounds great bud. Glad to see you have it going again
Old 08-16-2020, 06:38 AM
  #556
Mickyinks's Avatar
Thanks mate... Im pretty happy seeing tho it was my 1st cam install into a car . Ill get it on the dyno this week and see how it goes. My street tuning isnt ideal, due to lockdown i really cant drive it far or long enough to get consistent data
Old 08-16-2020, 10:10 AM
  #557
TTur1996's Avatar
Sounds Great Mick. Congrats!!!! You going to try out drag week since you have the hitch? I bet that would be pretty sick smoking someone with trailer behind you. Lol
Old 08-16-2020, 01:51 PM
  #558
ramairws6's Avatar
Sounds like your poppin popcorn. Bet it even smells like that hahaha
Old 08-19-2020, 06:22 AM
  #559
Mickyinks's Avatar
bit of drama today. Driving along , look in rear view mirror and see a little smoke. Pull over and as I get out I see flames between hood and windscreen.
adrenalin kicks in big time. Grabbed the front passenger seat fire extinghuiser, I also have 2 in the boot, opened bonnet and it was lit up real good between rear of engine and fire wall. Put it out, luckily not far from home and could roll there.
melted a bit of the engine harness. Started to problem solve and found the valve cover gasket had leaked at very back of the head, oil then went down back of engine onto hot extractors .
Replaced gasket, harness wiring looked intact but no start. Found crank position sensor a little melted so replaced n still no start. Not getting fuel so I'll replace crank sensor and I'm 99% sure thtll fix it
what I will say is if you have a modified car and don't carry a fire extinghuiser, seriously consider getting one.
If I hadn't had mine the car would hv burnt to the ground.
Other than that I'm up to about 70% throttle with street tuning and engines feeling strong
Old 08-19-2020, 06:33 AM
  #560
bortous's Avatar
Oh wow.
Lucky you caught it in time.
Why would something like that happen?
Is it something you could check before going for a drive.
I hear ya with the fire extinguisher.
My VZ actually came with one mounted in the boot.
It's still good to go.
Quick Reply: LSX 454 freshen up
