Which Cathedral Head is best?
Thr tfs head isnt the best ls7 head. Thats purely subjective. They are great heads but there are much better out there.
https://www.edelbrock.com/victor-jr-...ock-61339.html
I say this if you got a good porter you can make Anything work or go fast.. 5.3 heads on a 346 running 10's think about it. May have 9's but you guys catch the point.
Head swap will Not do as much as a bigger engine....same $ spent on a small bore head would or could buy a Bigger motor....You trying to buy heads for HP is good but ....the question you should ask yourself what is my goal...other wise your like a dog chasing it's tail. 750 and 800 were mine and knew 400 & 8 cubic inches could do both and be streetable.
Wrote it twice for a reason... ^
Solid roller time as Tuskey said.
A 454 or 430+ ci would do or could do this with with ease & plastic intake. How do I know? TSP 454 made 750 with a factory plastic intake and Hydraulic roller.
what rpm are you revving the engine out to?
Next engine will be an LS7 spec at 427cid with a 4.125 inch bore.
Ok ER and I both said as close as you can get
With Flyin and his 416 the 1st go round with a hydraulic.
LS2 based 403" 13.5:1 to run on E85
Frankenstein Racing Heads stage 1 LS3 heads
299/212@.400
363/236@.600
371/247@.900
Super Vic port matched to heads. No plenum work
Mark Whintner prepped BLP LilBo
SRD spec'ed hydraulic roller 248/268 .684/.667 112+5
PAC 1207x
Smith Bro's pushrods
Lunati's version of the Morel 5206
Comp Ultra Pro Magnum rockers, bolt down version
2" to 3.5" merge collector ARH headers
https://www.yellowbullet.com/threads.../post-52347546
Only difference in Speeds or Flying is one has more compression and the other has a SR vs the higher compression hydraulic roller...no major HP difference
https://www.enginelabs.com/engine-te...ild-with-ffre/
http://www.lsxperformanceparts.com.a...re-9-240-deck/
What you think?
