What heads for a N/A 408ci?
I found out There is No one Here that was Teaching Anything about a head and there Still isn't.
I did say, see 1 do 1... I'm trying to Copy Darin's work on the spare Head that hit the Water jacket. The Works done just hit a bad spot🤣
Duplicate it and don't hit the Water jacket 😹
It's said that where you spend your Time is Where your Heart is @.
On cylinder heads it's a Birther thing.
So again
$3000 on SpeedMasters Ls7 heads + the $2300 that was stolen $ + $1100 new Money Spent on block work?
And I'd do it again to Learn what I did. You can Fool some of the people some of the time but not All the people all the time. You can make Hp with Pretty Much Anything if you know a good guy 👉Who's not bias = they're willing with the Knowledge to Port Anything you may have: a Brand nor manufacturer Has No Meaning it's Just a Cylinder Head and what's your Budget. 243's,Ls3's,Speed Masters, TFS, etc....
Also there are many here who attempt to educate. I have posted podcasts with darin Morgan, headgames and godbold many times.
Besides that look at most of you guys builds, they're Great and most are Similar because it's a great Thought.
But! I've looked @ few, rather a lot, R they not Damn Near a Carbon Copy of one another and Great.
I said do the same thing With any idea you may have on a person's build. Copy Someone's Baseline not Dependant on heads used Factory or aftermarket. Does one Have to just buy Mamo stuff to Duplicate or copy.
Let me know this ... anything after that is BS.
factory Ls6 243's with a 2.10 valve has Airspeed what's your point.
Guy says 243's and 600rwhp the 1st thing said is 8500 and it's gotta be something geared towards racing. But let's stick to air Speed.
Measley 408 with a thought out plan made 600 with a plastic intake. Well I'll be darned. With good compression for regular ⛽ gas.
Ok Texas Common sense being used. That build if Copied and thought out Couldn't we use TFS/AFR/ All Pro 235's out of the Box to get a similar result. Add porting 4 more if wanted?
Copy...you have the Answers
All I said.
We get back to the point of Anything is great if thought out. Find a build that's near what you may want...
I been told to expect about 450rwhp from a 370 with 12cc domes, 238/246 cam and non-ported L92's that's not for street car oriented/roll racing scenarios but I'd like to think it will make more than that NA. Duh, copy it and up the Ante? SpeedTrigger 402? Copy Ante Up? There thoughts used as my own.
https://ls1tech.com/forums/generatio...hp-484wtq.html
Cam looks Similar to any other Typical new age Ls7 cam done here.
Know research to see the cam spec's?
https://ls1tech.com/forums/dynamometer-results-comparisons/843097-408cid-all-motor-corvette-601-rwhp.html
hp/tq Differences on a 408 vs a 427 will be seen in Bore Differences not Rpm and Stroke Differences. Cam for either can and could be similar in terms of Duration. Same 4 inch arm being used.
