LS crankshaft rear journal flexplate bolt holes
My 6.0 is on the engine stand andI'm priming the oil pump with the summit socket and drill. It goes to about 58lbs but it has oil coming through the flexplate bolt holes on the rear journal. I'm trying to picture why or how it would be doing that. I don't recall having to seal the flexplate bolt.
The following users liked this post:
G Atsma (02-19-2022)
Yup: you can just look up in there and see the rest of the crank.
Use the Permatex/Loctite "high temp automotive thread sealer with PTFE". Hanging on a card at yer corner parts store.
And if the bolts were in the crank this wouldn't have been an issue either.
