Pilot bearing question for LS2
Old Jun 22, 2005 | 07:17 PM
Rick@Synergy's Avatar
Default Pilot bearing question for LS2
Anyone seen this yet? Got an eagle crank in this LS2 we are building and the stock pilot bearings dont fit. They just slip in and rotate around. Anyone got the answer for this?
Rick
Old Jun 22, 2005 | 07:41 PM
HALLZ's Avatar
Rick,
I guess SLP had issues with that for a bit too!
Old Jun 22, 2005 | 07:47 PM
Nickn20's Avatar
isnt that a eagle crank issue?
Old Jun 22, 2005 | 08:13 PM
ChucksZ06's Avatar
I am going to mic my eagle crank before I install engine. Thanks for tip.
Old Jun 22, 2005 | 11:09 PM
Yup, just one other thing holding me back from putting this damn motor in.
I dont get this **** sometimes, they dont check this from the factory? Its a freaking 15 dollar part, be nice if they just try one.
Rick
Old Jun 23, 2005 | 04:21 PM
ls1240z's Avatar
Great!!!I have the exact same problem you do.I bearing just falls into place.I called the place I bought the kit from and they are in the middle of contacting Eagle to find a solution.He said that they probaly make a bushing that will fix the problem.I'm waiting to find out.
Rick
Old Jun 23, 2005 | 05:45 PM
I am having one made today and I will let you know how it turns out.
Rick
Old Jun 23, 2005 | 11:48 PM
ls1240z's Avatar
Yeh,definetley.I want to know because I might need one.
Rick....Were you the guy that raised my Pewter C5?I think I delt with you when I came to your shop.
Rick
Old Jun 24, 2005 | 12:16 AM
Yes, that was me. What we did for the pilot bearing today was just an old trick one my my friends told me to do. We took the bearing and brazed the outside with tin solder. So now it has another layer of metal around it and should help it snug itself right in there. Will let you know in the morning.
Rick
Old Jun 24, 2005 | 06:56 AM
mikey's Avatar
LS1TECH Sponsor
It is a tolerance problem with the POS eagle cranks. Cheap chinese parts
Old Jun 24, 2005 | 10:54 AM
And of course Eagle wont call me back either.
Old Jun 25, 2005 | 10:55 AM
ls1240z's Avatar
Of course they wont call you back.I guess I wont be buying anymore Eagle cranks.*********!
Did the brazeing thing work?
Old Jun 25, 2005 | 11:05 AM
It worked freaking perfect. It just needed a few thousandths more and wammo, tight fit.
Rick
Old Jun 25, 2005 | 11:24 AM
T/A Medic's Avatar
make sure u let ur customer know
What happens of the brazing falls off or something happens and the pilot bearing comes out... there goes is drivetrain. And your responsible. At least if u let ur customer know and he doesnt want to wait for a new crank he can sign a waiver.
If it was my motor I would rather have the right crank specs.
Old Jun 25, 2005 | 12:05 PM
My customers know everything I do with their cars, matter of fact he was here so I could show him.
Adding tin for fitment is not something new for builders and has been done for years as a fix. When you use solder or tin, you are applying at an extramley higher heat than what the crankshaft will see. So no need to worry.
I also think waiting for another motor is not something he is wanting to do at this point. The motor is fully built and ready to go in. Thats when we ran into the pilot bearing issue. Trust me, its tight in there, I had to use a mallet and an installer to get it in, so I consider it like stock now.
Rick
Old Jun 26, 2005 | 12:59 AM
ls1240z's Avatar
Rick....That's a sweet idea and thinking of doing it my self.Your not concerned about getting the barings real hot or warping.You think the grease melted out of it.You think silver solder would work just as good.This is the only thing holding me up too.
I need to get this motor in the RX7 NOW!
Rick
Old Jun 26, 2005 | 06:57 AM
Plan B's Avatar
Question; How do you make sure this fix is centered corectly?
Old Jun 26, 2005 | 10:49 AM
Because the bearing needed only a few thousandths to make it snug and when you braze solder tin all the way around it, its centered. You just needed enough to have some friction between the sides. Its not alot.
Rick
Old Jun 26, 2005 | 10:50 AM
THe tin solder take alot of heat, more then the motor will ever see to melt it again. So it should hold good. Bring it by if you need me to do this for you.
Rick
Old Jun 26, 2005 | 03:46 PM
ls1240z's Avatar
Thanks alot Rick....you the Man!
Rick
