How to find Shirl Dickey for my 418cid. 4.100 crank
Im building a 418cid. I ordered a new 6.0 aluminum LS2 block and a Eagle 4.100" crank and Eagle 6.125" rod I need to know if i need to have the # 8 piston cut for the reluctor ring and what brand pistons to get for a 4.100 stroke & 6.125" rod can not find them any were on here, and is 0.030" over bore safe
Yes I know, I call (ROSS) and they make the pistons for my motor ,They told me that thay can make me a set of custom piston for a 418cid and they also cut all there pistons out for the relutor ring so they will all weight the same and dont haft to worry about putting the rong piston in the wrong hole, and plus they will balance out right, and could make me any compesson i want ,is 12.1 to much for 93 octane.
Yes I know, I call (ROSS) and they make the pistons for my motor ,They told me that thay can make me a set of custom piston for a 418cid and they also cut all there pistons out for the relutor ring so they will all weight the same and dont haft to worry about putting the rong piston in the wrong hole, and plus they will balance out right, and could make me any compesson i want ,is 12.1 to much for 93 octane. price was $780.00 for pistons and rist pins and clips and a $100.00 buck for the rings a total $880.00
if you're going to spend that kind of money to get a 418 why on earth would you use an off the shelf cam designed for STOCK heads and displacement? I would recommend getting a custom grind for what you want out of the car.
Nate
a 5.3 stage III head,custom ported & polished Farra 2.05"int. and 1.65"ex. polished combustion chamber, heads milled 0.030, 3 angle valve job, Patriot gold valve springs, and for the cam this is the cam that in my all forged 348cid. motor right now ,and will up grade to a bigger cam , What cam would be a power house cam for the street and strip for a 418cid. I have a 250 shot pro fogger N.O.S. M6 ,8.8 ford rear end , 4:30 gears , full race suspension .The only thing that's stock is the body and of you count the strip kit it's not ether
i would call futral or EDC and get a grind. I would guess something like a camotion grind 250/254 .64X on a 109 would be make good mid range tq and be a really good street/strip cam.
