cheaper 427
Old Jul 10, 2006 | 05:25 PM
who281's Avatar
Default cheaper 427
if i wanted to build up an engine for my F-body would i be better of going with an LS7...an aluminum 427 from sum1 like LS1 speed or a iron block 408....
how much would these cost installed...how hard would they be to install myself??
Old Jul 10, 2006 | 05:47 PM
Ferocity02's Avatar
An iron 402/408 iron block is pretty cheap, depending on the components you want to use. 402 LS2's are fiarly affordable, and even more so if you buy and build the motor yourself. Above a 408 starts to get real expensive because you start to need sleeved blocks, which are $$$. A 427 won't be cheap no matter what you do. And sometimes if you try to go cheap you just end up paying more.
Old Jul 10, 2006 | 06:40 PM
Katech_Jason's Avatar
LS1TECH Sponsor
We are currently building our 427 budget short blocks. Stay tuned...announcements soon.
Old Jul 11, 2006 | 12:57 AM
rjkZ28's Avatar
please post info as soon as the 427 budget shortblocks are ready, im curious my self. i saw mti had a 427 too
Old Jul 11, 2006 | 09:11 AM
viewsonic's Avatar
why do you tease us like this?
Old Jul 11, 2006 | 12:28 PM
SideStep's Avatar
VERY interested, will this be based on the L92 block???
Old Jul 11, 2006 | 10:09 PM
Billiumss's Avatar
Exclamation
Very interested to see what you guys have...
Old Jul 12, 2006 | 12:07 PM
UCABlackChevy's Avatar
If it is based on the L92 block, which the bore is 4.06, then that means that the crank would have to be 4.125 to make 427 cubes. That would be the only way to do it without resleeving a L92, LS1, LS2 block.....unless they use the LS7 block which would defeat the 'budget' part so the LS7 block is out of the question.
Old Jul 12, 2006 | 12:41 PM
LS1TECH Sponsor
It's our resleeved LS2
4.125 bore x 4.000 stroke
Old Jul 12, 2006 | 12:59 PM
Ah, I see, that is good I didn't think the 4.125 crank with 4.06 bore would work too well and would probably require custom pistons.......since its going to be a resleeved block i was wondering, if i could ask, approximately how budget it is going to be?
Old Jul 12, 2006 | 01:55 PM
GuitsBoy's Avatar
Will this cost me one nut or both?
Old Jul 12, 2006 | 02:11 PM
1 last 1's Avatar
I have no facts in front of me but I would lean towards the both...
Old Jul 12, 2006 | 02:41 PM
LS1TECH Sponsor
The goal is under $7000. We'll see.
Old Jul 12, 2006 | 02:43 PM
Nate_Taufer's Avatar
L-92 is actually a 4.065" bore. So cleaned up to 4.07" would be no prob. Add a 4.1" eagle crank and voila...427 cubes.
Nate
Old Jul 12, 2006 | 09:53 PM
valdeztke's Avatar
Old Jul 17, 2006 | 09:25 AM
Billiumss's Avatar
Exclamation
"Budget", please explain? Did the price drop on the sleeves?
What's ALL included in that price.
Old Jul 17, 2006 | 10:07 AM
viewsonic's Avatar
I would also like to know...
What's in it?
Old Jul 17, 2006 | 10:14 AM
LS1TECH Sponsor
What's in it?
Katech resleeved LS2 cylinder case 4.125
-Dry sleeved
-Double vacuum impregnated
-decked
-clearanced for 4.000" stroke
-utilizes production main caps
Cola 4.000" stroke crankshaft
Callies H-beam rods
Katech forged pistons
Federal mogul / Clevite bearings
Precision race engine assembly by the same engine builders that build for ALMS, World Challenge and Grand Am.
We are building today and I will be making announcements very soon.
Old Jul 17, 2006 | 10:41 AM
Billiumss's Avatar
Question
$7k for a short block doesn't sound like much of a "Budget"
How is that cheaper than using a LS7 block?
For most people, including myself, using the term "Budget 427" means the least expensive way to get 427 cubes.
I guess my only concern is the vauge use of the word 'budget'.
Old Jul 17, 2006 | 10:48 AM
MrDude_1's Avatar
by budget they mean less then 12,000..... in otherwords, budget for the guys with huge budgets.. not budget as it refers to 95% of the people on this website.
for a normal engine builder, id expect a budget motor to have the price start with a 4... maybe a 5 if its using thoes cranks and rods.. but still, id expect it cheaper.
