L92 DynoJet Numbers Plus Plan B, C, D, E and F...
Old 07-28-2008, 09:20 PM
  #481
Cobra4B's Avatar
Awesome... so does this mean a 2001 and later PCM has more tuning capability? If so, this would be the first Ive heard of that.
Old 07-28-2008, 09:23 PM
  #482
WKMCD's Avatar
The 97-98 have less refined tables and a slower processor. Ed had to repin the entire PCM harness to use the newer PCM. The 99+ are pretty much all the same.
Old 07-29-2008, 07:15 AM
  #483
edcmat-l1's Avatar
Kinda felt like this for a few hours after staring at all that little crap.
Me eyes aint watt they used to be.
Old 07-29-2008, 10:37 AM
  #484
WKMCD's Avatar
As long as it's just your eyes, you're in good shape for a man your age.
Any time on the dyno yet?
Old 07-29-2008, 10:50 AM
  #485
edcmat-l1's Avatar
Workin on the tank sender right this minute. Seems its the pass side one, not the drivers. Looks like its not picking up the last 2, 3 gallons from that side.
Should have it on the dyno later today.
Old 07-29-2008, 11:35 AM
  #486
veee8's Avatar
Can't wait to see the results!
Old 07-29-2008, 12:01 PM
  #487
WKMCD's Avatar
WOOHOO!!! Fingers crossed. I'm not really thinking we'll pickup much if anything up top but hopefully pickup some nice RWT and average power.
Not picking up three gallons is about right based on empty to full.
Old 07-30-2008, 02:52 PM
  #488
veee8's Avatar
Do you have the Weiand on order?
Old 07-30-2008, 04:26 PM
  #489
WKMCD's Avatar
I'll order one WHEN/IF they are available.
I spoke with Ed this afternoon. Some other small work is holding things up some. He had to order the passenger side sending fuel sending unit today. He should have it tomorrow. We should have some more info then.
Old 07-30-2008, 06:02 PM
  #490
veee8's Avatar
Hopefully that will take care of the fuel pickup issues.
Old 08-01-2008, 04:54 PM
  #491
WKMCD's Avatar
So here's where we are today.
The gas sending units are in and the problem of not picking up the last 3 gallons from the passenger tank is fixed.
The car is back running closed loop using the PLX WB as a WB/NB. He put a GM 02 in the passenger side. The late model PCM is in and the car has a base turn on it but idles well and is producing similar numbers to the previous setup which is no surprise to us at this point.
The car is pulling a lot of vacuum so we're fighting a restriction. Ed is thinking the TB or maybe MAF. He's going to do some more testing in the morning to try to rule out - or rule in - the 85mm MAF. We both really think it's the ported LS2 TB. I'm trying to get my hands on a 95mm drive by wire TB and if we need to a 100mm MAF. All this is really in anticipation of the vacuum issue getting worse when/if a new manifold comes out. If they don't produce I'll have a sheet metal made this winter with runners in th 8 inch range.
Even as it sits, drivability will be greatly improved and it was damn near perfect before. We'll see what Ed discovers tomorrow.
Old 08-01-2008, 05:00 PM
  #492
LS1 Tech Administrator
Patrick G's Avatar
Greater vacuum at WOT than before (as long as nothing else has changed besides the cam) is encouraging. That usually means the engine is sucking harder. More demand for airflow usually means more power.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 08-01-2008, 05:51 PM
  #493
WKMCD's Avatar
Only the cam change would causse this now. It is the kind of problem you want to have. Ed's going to run it MAFless in the morning to see if that's the culprit. It start pulling vacuum hard at about 5400RPM. I've got a call into Tracy at REV about his 95mm DBW TB, That's the only one I know of. We can open up the L76 enough to accomodate that. It will be right up against the endge of the o-ring but a little RTV will take care of that.
Old 08-02-2008, 05:14 AM
  #494
See5's Avatar
Think you are up against the intake manifold flow restriction. The 90mm TB should more than flow the intake. You are pretty much maxed out for the configuration. The few hp to be gained are going to be exponentially expensive and "iffy"
I had a similar 402 and got similar power, I found you just can't stuff much more air in there-
The new upcoming manifolds are looking for "magic" to some degree. The basic longer -shorter runners rules still apply and there is only so much you can fit under the hood of a C5.
Old 08-02-2008, 06:32 AM
  #495
WKMCD's Avatar
I would have thought so and yet we are showing a restriction before the manifold but thanks for the advice.
Old 08-02-2008, 02:17 PM
  #496
Phil'sC5vette's Avatar
Kevin,
Can you tell us what was happening with the car before you switched PCMs.
I know the newer PCMs have more tables to adjust, but why ( maybe in the first 25 pages you have that already lol)
What was the car was doing on the bad side that you are trying to fix?
there's never anything wrong with at little a couple more ponies, but that does seem to be what you are looking for.
Im sure one day Ill need a new motor and im trying to learn what to do and what not to do and why
Old 08-02-2008, 03:12 PM
  #497
WKMCD's Avatar
Originally Posted by Phil'sC5vette
Kevin,
Hey Phil, There was nothing that necessitated a PCM swap or for that matter a cam/springs swap. I just felt that it could be incrementaly better. As I've said all along, this is a creative exercise and an ongoing process.
Old 08-04-2008, 10:09 AM
  #498
1ORANGEWS6's Avatar
Sounds like those budget truck heads are doing pretty well.
Old 08-04-2008, 07:06 PM
  #499
ringram's Avatar
I hope you finish soon Kev because its holding my darton engine up
Old 08-08-2008, 10:44 AM
  #500
94 guy's Avatar
no news?
Quick Reply: L92 DynoJet Numbers Plus Plan B, C, D, E and F...
