L92 DynoJet Numbers Plus Plan B, C, D, E and F...
#852
That's good for stock intake, The JT cam is no more and out dated
Do you have any engine dyno sheets to post up?
We find on the engine dyno with some of the restricted speedway engines that they have vacuum at WOT, a power valve change is a must then. Removing the restrictor plate and changing to a better manifold removes the vac restriction. Currently Im at only 96 kpa with OTR on aswell so I'm in need of a manifold aswell.
#854
We'll see what happens when Shawn starts cutting up the FAST.
VA Speed is right at sea level so the Kpa should be very real with no need adjust for altitude. I stayed upwards of 98-99 with the 4 inch downtube. Before that it would drop to 93-94.
#855
Shawn should throw the Fast on first before he does any work to it, Just to get a baseline. Then do the work he intends. My guess is this is what he'd probably do anyways. It would be sweet if the car picks up what he thinks it can with the Fast, I know it would make my day too
#856
#857
#859
1 Post
looking good on the results Kevin. Nice to see the numbers going up. Unlike my just received house assessment. Gotta love living in Michigan. At least my taxes go down. Ok back to Kevins monster 427 !!
