Question: L92 heads on a 4.125" bore?
However, I'm worried about the combustion chambers of the L92 which are designed for a 4.065" bore. The Katech block is 4.125, so the head will 'overhang' the bore by about 0.030".
Is this a big deal? Are there any downsides?
-ch
-ch
Or do this:
https://ls1tech.com/forums/showthrea...ighlight=shirl
Make a 427 from an overbored L92 block (.015" overbore) and 4.1" stroker crank: The factory bores were straight, no problem. If you don't want to go all the way to 4.100" on the L92 bore, why not go 4.080" with a 4.100" stroke and you get a very nice 427 cid...
Shirl Dickey
What I'm wondering is if the overhang will cause any 'problems' i.e. quench issues, etc.
-ch
