Just installed AMW Catch Can
I just finished installing a beautiful Catch Can made by Todd at AMW in Texas. I attached it to the passenger side head with an adapter made by Dark Age 53, which fit perfectly! The whole installation took about 30 minutes because I had to take time to admire the nice machine work on the Catch Can.
Now maybe I can keep most of the PCV oil out of my new LS6 Intake.
Here's a link to AMW:
http://www.accmachtech.com/pcvcatchcans.htm
John
John
that's a nice looking oil catch system. I have a little detonation at low rpm (only sometimes), am I correct in thinking something like this will help resolve the issue? I do get some oil residue on the back of my throttle body plate...
are there any other oil catch kits being made now? It's a beautiful can but 88 dollars seems a little spendy.
When I saw all the oil inside my stock intake manifold and inside the intake ports on the heads, I would have paid $100 for something to stop the oil. If you take your throttle body off and feel inside your manifold, I bet you will find a heavy, unhealthy coating of oil. As far as eliminating low rpm knock, I really don't know. What I do know is that burning oil leaves deposits in the combustion chamber which can create hot spots, which leads to detonation. I think, ideally, there should only be gas and air going into the chamber.
IMHO,
John
IMHO,
John
Race your car!
I also got the same setup, including the dark age bracket. Choice stuff, and it works. After about 500 miles, there's a boatload of crap in the bottom of my catch can, and the throttle body and intake are looking cleaner. Both good things, and a good way to permanently solve an annoying problem.
Originally Posted by mdhmi
Very nice. I have one of their catch cans on my Vette along with a Metco valve cover breather and that has very much curtailed oil consumption.
Mark
Mark
Race your car!
There's a guy on here, his name's darkage53, real name's Al. He makes a bracket so that the can can be mounted in the holes where EGR on 99 cars goes. Real slick setup, and worth every penny. Gives the install a total factory look, and a convenient way to mount without drilling holes in your ride, and is in a easy place to see the contents and drain as nessassary. Send him a p.m., he may be making another lot soon.
What does the Metco Valve Cover Breather do? I know it releases crankcase pressure but what exactly does that mean? Does that stop some of the oil from getting inside of the intake manifold? Do the breather and catch can kind of do the same thing, as far as the ultimate goal to keep oil in the engine and not on top?
I am also getting ready to put on an LS6 intake that I had painted along with a ported/powdercoatedrted TB and I didn't want to get any oil inside of them. I looked inside of my LS1 intake; actually swabbed the inside with my finger and while it was dirty, there was no oil. Should I just get the breather and call it a day?
Also, I think the Metco breather is too tall. I wanted one that was more shallow. How come these things in AutoZone only cost $15 and the Metco cost $50? Can I modify one from Autozone to fit? It might even come out shallow like I want. Thanks- Mike.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by hugger427
get the can...you'll see ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Would anyone know if the catch can gets all the oil. I Installed double air oil separators on mine and still finding oil in the second separator. If I went to the AMW catch can would that get all the oil? Perhaps someone migh want to try putting a clear separator between the catchcan and intake to check for oil.
Not in my case. It catches about 80% of it and that is far better than before. I drive my car at open track events (20 minute sessions on road courses at high rpms).
Yesterday I went off course and slid the bumper cover into the sand. It knocked loose the petcock valve and droped about 4 oz of oil on the ground.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![](http://www.geocities.com/curtnovak/catch/lines.jpg)
I was very relieved to trace the oil back to the catch can and not the block or radiator. This was after only 50 minutes of spirited driving.
