I think I've picked out some wheels.
I found these on tirerack.com, what do you guys think?
MODA MD5
![](http://www.tirerack.com/images/wheels/moda/swap/moda_md5_bsml_ci3_l.jpg)
18 x 8 inches - $179/wheel
Offset: +40mm Backspacing: 6.10" Bolt Pattern: 5-115
19 x 8.5 inches - $149/wheel
Offset: +40mm Backspacing: 6.37" Bolt Pattern: 5-115
Question though, what is the centering ring and a retaining clip for AL-P ring for?
MODA MD5
Well other manufacturers have claimed that their wheels are hubcentric and will work with our w-bodies but go to the ASA sticky at the top of our section and learn of the possible danger of installing wheels without a small spacer or a centering ring.
Thanks for the info Nacho. I read about the ASA wheels. I'm hoping these wheels here do not have that issue.
pro_performer what you will need to do(like in my case) mount the wheels up and torque them down. Then take a feeler gauge and run it between the wheel(hub mounting surface) and the rotor hub surface, if there is a gap...you will need a spacer like I did. Even as tiny as a piece of paper. Trust me. Or you could just let me know when you get the wheels and we can check it out. Up to you.
So just to be clear-When installing afetrmarket wheels on,let's say my GXP, I should install hubcentric rings.
By the way thats a good looking wheel. What size are you going with? The 19's would look sweet on a lowered car.
Aftermarket wheels tend to have a larger center bore, thus the hub centric rings. Its not necessary to run them but it does help with vibrations and helps the wheel make contact with the hub.
