teardown has begun!
"Hi Robert,
The JTFM will stall to 2800-3000 rpm in all supercharged and LS4 equipped vehicles so you are right in the ballpark. The book ratings are way off and there is much more involved in how it actually stalls up. The converter should definitely be locking up and pull the rpms down in 4th gear so watch scan data and verify it is locking up and you should see TCC slippage rpm constantly float around 0-50 rpm with brief fluctuations about that and TCC apply/duty % around 48-58% at a steady cruise.
Fuel economy can be effected by several things so I would make sure you don't have vacuum leaks or the 02 sensor isn't performing well. If the ECM is adding a lot of fuel via fuel trims then there is a reason for it and will make mpg drop."
"Converter wise due to the size of the converter and weight of the vehicle you aren't going to get much of a lower honest stall speed. There is one step down converter that will stall in the 2600-2700 range but normally something I only suggest for stock applications. The rpms you mentioned all sound about normal to me but is hard without driving in person to say for sure. These cars normally won't move until the rpms are over 2000, though the stock 2.93 ratio effects this as well. There can be a small amount of variation in stall speed but I have not installed one of these yet to see a drastic change. The more power the engine makes will also give a looser converter feel also as the stall speed is a direct relation to torque input.
Converter wise- The ZZP converter is not going to help what you are going after. Their 2500 converter is close to a JTFM, but the smaller size and what is based off of may even be a bit looser feeling as going down in converter size is going to effect this plus you get a smaller and weaker lockup clutch which is not something you need in a vehicle that likes to eat torque converters. If you want a better torque converter that would be custom built to suite your needs I would suggest one of our performance converters from Precision Industries. They are not a one-fits-all torque converter. These are based off of a 245mm converter but are all custom built per application, have a higher torque multiplication, and a custom billet oversized lockup clutch piston. A big plus is they come with a 5 year warranty and one free stall speed change if you need."
Frankly I just dont have it in the budget right now to change the converter out with a 850 dollar performance replacement. I could look into circle d and FTI already told me they would custom make a converter for me for about 350-400. Could also give precision of new hampton a call as well who actually made this converter, see if they could do something custom again like they did for my integra. They did a 3000 stall for my integra and it was spot on.
, Such a big difference, did it effect any tuning?
