LS6 Intake - getting closer
Old Mar 13, 2009 | 07:50 PM
  #81
speedshifter's Avatar
Originally Posted by Brian396
https://ls1tech.com/forums/attachmen...t-proxt-ls.jpg
I got 9 ½” from the valley cover to the hood insulation on the 06 GXP
So with hood insulation removed, this manifold should fit huh? I wonder if the inferno hood would help out at all with clearance.
Old Mar 13, 2009 | 08:27 PM
  #82
Panther427's Avatar
I think it would be worth it. i could only wonder how much better that manifold would be with a turbo/supercharger vs just using the stocker. I bet you would gain alot of power on a Turbo/supercharger app. Gain alot more flow on the top end. It would lower restriction probally see a drop in PSI. Lower IAT temps then be able to bump up your boost a few PSI and saftely make more power
Old Mar 13, 2009 | 09:28 PM
  #83
Mgpeagle's Avatar
That thing is nasty! (In a good way...)
Ok, who's the Guinea Pig?
-Mike
Old Jun 10, 2009 | 09:37 AM
  #84
JDMC5's Avatar
Update tired?
Old Jun 26, 2009 | 10:54 PM
  #85
AlabamaGuy's Avatar
Bump for an update
Old Jun 26, 2009 | 11:06 PM
  #86
TiredGXP's Avatar
https://ls1tech.com/forums/ls4-front...-problems.html
post #16 pretty much says it all.
Old Jun 26, 2009 | 11:22 PM
  #87
AlabamaGuy's Avatar
Originally Posted by TiredGXP
Understood. I have a few of those projects laying around myself.
Old Jun 26, 2009 | 11:31 PM
  #88
Panther427's Avatar
Thanks for all the effort. Its a good stepping stone for the rest of us.
Old Jul 19, 2009 | 05:49 PM
  #89
Maybe this has been considered already, but what about using this adapter and relocating the oil pressure sender:
http://www.lingenfelter.com/mm5/merc...egory_Code=C54
Sure its not the smartest alternative because you are taking an oil pressure reading pre-valvetrain, but its still an oil pressue reading. Then you could just put a plug in the stock hole in the valley cover, right?
Old Jul 19, 2009 | 05:57 PM
  #90
neilownz's Avatar
Another way would be to use a remote oil filter kit and some fittings...
In the aluminum block above the oil filter there is a port. It just needs to be drilled and tapped.
Found that in the Gen IV section, but I don't know if we have one.
Old Jul 19, 2009 | 06:30 PM
  #91
Yeah we do, I guess you could drill/tap it, but I don't think you would have enough room to just install the sender right into that hole, you would need to configure it with at least a 90* elbow or something.
Old Jul 19, 2009 | 07:07 PM
  #92
neilownz's Avatar
I think it would be easier to just move it to the rear of the block below the tb. Drill/tap it to line up with the current passage. Then the wires etc would fit without much trouble.
Old Jul 19, 2009 | 07:10 PM
  #93
how do you think it will fit? The exhaust crossover and coolant pipes are in the way:
Old Jul 19, 2009 | 07:21 PM
  #94
TiredGXP's Avatar
Looking back, I should have gone with the LS2 valley cover and ditched DOD entirely. That would have made life a whole lot easier. This would have let me go with the FAST intake and LS2 DBW TB. Just a small wiring change for the LS2 TB and no need to make an adapter.
There have been a couple of LS7's shoehorned into Fieros with the intake in the reverse (FWD) orientation that managed to fit the 90mm TB's.
Old Jul 19, 2009 | 07:25 PM
  #95
neilownz's Avatar
Thats interesting. I'm sure there's more room, but my car isn't here right now to check.
Old Jul 19, 2009 | 07:37 PM
  #96
Yeah but I wonder how much gas mileage would be lost w/o DOD. Right now i avg 17.8mpg and in February when I first got the car I averaged 16.7mpg.
My DOD works flawlessly and I never feel or hear it engage or disengage.
Old Jul 19, 2009 | 08:12 PM
  #97
TiredGXP's Avatar
Back in 2005, GM advertised up to 12 percent improvement in EPA tests...
http://media.gm.com/division/2005_pr...005i%20LS4.doc
I've driven with DOD disabled, which decreased mileage by 8% for the way I drive, so maybe I save 4-5 liters per week with DOD enabled
Old Jul 19, 2009 | 08:17 PM
  #98
Yeah thats a decent enough drop in gas mileage that I would want to keep the DOD. I wonder if anybody will pony up with the $600 to get the edelbrock intake/fuel rails and see if it clears everything. It looks like the hardest thing to over come would be the air inlet tube to the air box.
Old Jul 19, 2009 | 08:56 PM
  #99
neilownz's Avatar
I know. I'm just worried that sucker will hit the hood. The tubing size difference can be overcome with a few silicone pieces, bigger maf, etc. And a LS2 tb of course.
Old Jul 19, 2009 | 10:54 PM
  #100
Pauls325's Avatar
hows dod on a G8 work will an L99 vally cover work bbetter?
