Project gutted Formula
Old Jun 24, 2009 | 09:49 PM
  #181
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Yeah, that bolt took me a while to find. Once you know it is there you are ok though and won't ever have to worry about it again. I didn't search, but I think that box controls the VATS system.
I'll take a picture of the giant box of wires I removed from the body harness. There's tons of things you can remove in there. Just take your time and check each wire before you remove it. A lot of them tie into the same circuitry.
Old Jun 24, 2009 | 10:03 PM
  #182
3rdgen92maro's Avatar
The only things i removed from the harness where all the ABS stuff, under hood airbag ****, A/C wiring and Air pump stuff.
Old Jun 25, 2009 | 07:18 AM
  #183
wllbndthrw's Avatar
Originally Posted by 3rdgen92maro
Also what is the aluminum box with the 2 connectors under the left side of the dash for? Is it ABS stuff?
Does it have a number that starts with 161 on it? It goes to the ABS if it does
Old Jun 28, 2009 | 07:49 AM
  #184
Well i got all the wiring finished up. I got a 5 gal bucket full of wires in my garage.
Old Jun 28, 2009 | 09:17 AM
  #185
Today's project is to see if i can get it fired up and of coarse do some more cutting
Old Jun 28, 2009 | 09:22 AM
  #186
Fuels94's Avatar
Hey Shawn is the car on base now? if so I'll be out there later on doing stuff on the base.
Old Jun 28, 2009 | 09:45 AM
  #187
It sure is man. Deff stop by the house if you want to. I gotta run the wife out to work and swing by the general store to pic up some parts. I should be home around 11ish.
Old Jun 28, 2009 | 04:04 PM
  #188
well i got her fired up today...but there is a new problem it will only stay running on its own for like 2-3 secs then die. If i feather the pedal it will stay running but thats the only way.
Old Jun 28, 2009 | 04:19 PM
  #189
Well i am a retard...I got all excited to fire it up and forgot to hook up the vacuum hose to the power booster and to the crank case breather...idle problem fixed after that but she is idling pretty rough hopefully i can figure it out.
Old Jun 28, 2009 | 05:04 PM
  #190
kierstyn's Avatar
Been there done that glad it worked out. Take you a breather and get the rest worked out. Theres days I work on mine just fine then days when I get frustrated with it and leave it for a while then get back to it again.
Old Jun 28, 2009 | 06:37 PM
  #191
Yea this was one of those day let me tell ya. Hopefully its idling weird because the O2's weren't hooked up...i need to get my damn trans ASAP i wanna drive this turd already!
Old Jun 28, 2009 | 07:14 PM
  #192
Red93z28's Avatar
this is an awesome thread man the best of luck to you, let us know total weight reduction at the end, hope it works out for you
Old Jun 28, 2009 | 07:32 PM
  #193
Red93z28's Avatar
also i never understood this whole isolater thing for the rear suspension, i have eibach lowering springs on my car, with prostars(i no bad move on the springs but i got them for free) i would like the back a little lower, if i took these out, will it do that, and if so how do i do it, thanks again
Old Jun 28, 2009 | 09:30 PM
  #194
Hey man free is free. Nothing wrong with Eibachs i was going to get the prokit from them for my car but i got the qa1 coil overs, comp eng rear shocks and LCAs for $450
I would ditch the isolators and get some heater hose and a few zip ties to wrap around the top coil to keep it from squeaking. Should lower the rear a good 1/4-1/2 for about 15 mins worth of work.
Old Jun 28, 2009 | 09:31 PM
  #195
Thanks man. Hopefully it will be done in the next few weeks. I cant wait to see what it weights. Im hoping for 2800 with out me in it.
Old Jun 28, 2009 | 09:33 PM
  #196
Looks like ill finally be getting a TH350 and converter in the next week or so. Buying a build TH350 RMVB and a Yank 4k stall. Im stoked.
Old Jun 29, 2009 | 12:31 PM
  #197
Red93z28's Avatar
will it affect anything like traction etc?
Old Jun 29, 2009 | 01:05 PM
  #198
I highly doubt it. Lots of people on here running in the 9-10 sec range arn't running them. You could do a search in the drag racing section about them to.
Old Jun 29, 2009 | 06:34 PM
  #199
Just picked up a B&M trans cooler for it gotta get it installed tomorrow. I still cant decide what shifter to go with. I'm thinking a Hurst quarter stick but idk.
Old Jun 29, 2009 | 07:17 PM
  #200
Red93z28's Avatar
the quarter stick is sickk
